  8.22) Flameproof Resistors
Flameproof Resistor or Fusable Resistor are often designated by the
symbol 'FR'. They are the same.
You may see these in the switchmode power supplies used in TVs and monitors.
They will look like power resistors but will be colored blue or gray, or may
be rectangular ceramic blocks.  They should only be replaced with flameproof
resistors with identical ratings.  They serve a very important safety function.
These usually serve as fuses in addition to any other fuses that may be
present (and in addition to their function as a resistor, though this isn't
always needed).  Since your FR has blown, you probably have shorted
semiconductors that will need to be replaced as well.  I would check
all the transistors and diodes in the power supply with an ohmmeter.
You may find that the main switch mode transistor has decided to turn into
a blob of solder - dead short.  Check everything out even if you find one
bad part - many components can fail or cause other components to fail
if you don't locate them all.  Check resistors as well, even if they look ok.
Since they function as fuses, flameproof resistors should not be replaced
with higher wattage types unless specifically allowed by the manufacturer.
These would not blow at the same level of overload possibly resulting in
damage to other parts of the circuitry and increasing the risk of fire.
Then, with a load on the output of the power supply use a Variac to bring
up the voltage slowly and observe what happens.  At 50 VAC or less, the
switcher should kick in and produce some output though correct regulation
may not occur until 80 VAC or more.  The outputs voltages may even be
greater than spec'd with a small load before regulation is correct.
Chapter 9) Deflection Problems
  9.1) Deflection fundamentals
Note: the following is just a brief introduction.  For more detailed deflection
system theory of operationo and sample circuits, see the document: "TV and
Monitor Deflection Systems".
The electron beams in the CRT need to be scanned horizontally and vertically
in a very precise manner to produce a raster - and a picture.
For NTSC and PAL, the horizontal scan rates are 15,734 and 15,625 Hz
respectively, the vertical scan rates are 60 and 50 Hz (approximately)
respectively.
For PCs and workstation monitors, a wide range of scan rates are used.
For example:
      Standard      Horizontal, KHz  Vertical, Hz
        MDA               18.43           50
        CGA               15.75           60
        EGA               15.75-21.85     60
        VGA               31.4            60-70
        SVGA (800x600)    35-40           50-75+
        SVGA (1024x768)   43-52+          43-75+
        SVGA (1280x1024)  64-72+          60-75+
        Workstations      64-102+         60-76+
Even in high resolution fixed frequency monitors, these high horizontal
(in particular) scan rates necessitate some fancy circuit design.  All
components are running under stressful conditions and it is amazing that
failures are not more common.
With auto-scan monitors, the complexity of the circuits increases dramatically
to accommodate the wide range of horizontal scan rates.  Relays or electronic
switches are used to select power supply voltages, tuning components, and
to make other alternations in the deflection circuits to handle DOS VGA
one minute and Autocad 1280x1024 the next.  It comes as no surprise that
the most stressful time for a monitor is when switching scan rates.
Unfortunately, successfully diagnosing problems dealing with the scan
switching logic and circuitry is virtually impossible without a schematic.
The deflection yoke includes sets of coils for horizontal and vertical
scanning oriented at 90 degrees with respect to each other.  Additional
coils are needed to correct for pincushion and other geometric defects.
The deflection circuits must be synchronized and phase locked to the
incoming video signal.
Therefore, we have the following functions:
1. Sync separator to obtain horizontal and vertical synchronization pulses
   for monitors with composite video or sync inputs.  Input sync detectors
   and auto polarity switching circuits as needed for separate horizontal
   and vertical sync inputs.
2. Horizontal oscillator which locks to horizontal sync pulses.
3. Horizontal drive followed by horizontal output which feeds deflection
   yoke (and flyback for HV and other voltages),  Yoke requires a sawtooth
   current waveform for linear horizontal deflection.  Horizontal output
   in all but the smaller TVs or monitors is a large discrete power
   transistor, most often an NPN bipolar type.
4. Vertical oscillator which locks to vertical sync pulses.  Yoke requires
   sawtooth waveform for linear vertical deflection.
5. Vertical drive/output which feeds vertical deflection yoke.  Newer TVs
   and monitors use ICs for vertical drive and output.
6. Various additional deflection signals to correct for the imperfections
   in the geometry of large angle deflection CRTs.  These may be fed into
   the normal deflection coils and/or there may be separate coils mounted
   on the neck of the CRT.
7. Auto-scan deflection control and selection circuitry (auto-scan monitors
   only), probably controlled by a microprocessor which stores scan
   parameters for each scan rate and automatically detects the appropriate
   settings to use by analyzing the input video.  For horizontal deflection,
   the usual way of size constant regardless of scan rate is to scale the
   B+ to the HOT with horizontal frequency.  Thus, VGA resolution may us
   60 V B+ while 1280x1024 at 75 Hz may require 150 V.  Various other
   components may need to be selected based on scan rate.  Relays are often
   used for this selection since they are easy to control and can handle the
   voltages and currents in the various deflection circuits reliably.
  9.2) Monitor display is off-center
These sorts of problems usually relate to the picture shifting when switching
between applications or between DOS and Windows.
A couple things to check if you have a setup program for your video card
(1-3 are software adjustments in the DOS setup program):
1. Make sure you are running well withing the accepted scan rates for each
   resolution.
2. Toggle sync polarity and see if this makes any difference.
3. Adjust H position or phase and see what this does.
4. Make sure your cables are secure.  While a bad connection would likely
   messed things up worse, it won't hurt to check.
Your monitor may have a problem though it is not likely to be major (in
a relative way).  If you still like the monitor, repair may be worth the
money.  However, not doing anything now may lead to more serious (and
costly monitor damage.
  9.3) Gross problems in size or position at certain scan rates
First, make sure you are not specifying incorrect scan rate for your monitor.
Check your video card setup and/or monitor selection in Win95.
Assuming you are not violating the scan rate specifications but have a
picture that is twice the height of the screen and one half the width,
for example, this could indicate a failure in the scan rate switching
circuitry of an auto-scan monitor.  Either the logic is faulty and ordering
the wrong selections for power supply voltage and tuning components or the
relays or the relevant parts are faulty.  This could be due to bad connections
as well - quite likely in fact.  Also, try to reset the afflicted parameters
using the digital controls (if relevant) and confirm that your video card
is putting out the correct scan rate - try another monitor or examine the
video signals with an oscilloscope.
Try prodding the circuit boards with an insulated stick - this may identify
bad connections or unstick a sticky relay.
A schematics will likely be needed to proceed further with these sorts of
problems.
  9.4) Reduced width
Complaints about the picture not filling the screen with computer monitors
are common but may not indicate problems (except with your expectations).
Older monitors, in particular, often did not allow a full screen display
at certain resolutions.  There may be underscan modes/switches as well.
Keep in mind that advertizing a large diagonal CRT does not necessarily
imply that you can fill it!
However, if this problem just happened with no changes to your computer system
(video card, scan rates, O/S), then the following are possibilities:
* The B+ to the horizontal output is lower than normal.  The way width control
  functions is that as you increase the horizontal scan rate, the B+ to the
  HOT must increase to keep the width constant.  It could be that yours is
  low to start with and not tracking scan rate changes either.
* A bad capacitor might also result in reduced width but I would expect
  non-linearity as well.
* As noted in the section: "Gross problems in size or position at certain scan rates", there could be problems in the scan rate switching circuitry
  selecting incorrect components for certain scan rates.
* There might be a bad (low value or high ESR) decoupling capacitor.
  Scope the rail after the low-value decoupling R for H-rate stuff.
  There shouldn't be anything significant.  If there is, the ESR of the
  decoupling capacitor is too high or its value is too low.  Seen it
  often where it also cooks the decoupling R, because the efficiency of
  the H-out becomes poor.  (gwoods@albany.net (Gary Woods)).
* A more unlikely possibility is a open yoke winding.  The horizontal
  deflection yoke consists of multiple windings in parallel so it is
  theoretically possible for one or more of these to open up.  I don't
  know what effects the associated detuning of the horizontal output
  circuit would have in this case.
  9.5) Can incorrect or missing video damage my monitor?
The short answer is - quite possibly.  Don't push your luck.
Mostly, there are problems at scan rates which exceed the monitor's
specifications.  However, some poorly designed monitors or just a
particular combination of events can blow a monitor with too low a
scan rate or an absent or corrupted signal input.  There was one case
where a very expensive high performance monitor would consistently blow
its horizontal deflection circuits when driven by a particular ATI
video card.  It turned out that during the power-on self test of the ATI
BIOS, just the wrong video timing was being generated for a fraction of
a second - but that was enough.
As far as scan rate limits, there is no way of knowing - it really all
depends on the quality of the design of your monitor.  Some will happily
run continuously at 25% above specifications.  Other will blow out totally
at the first excuse.
The specification that is likely to be more critical is the horizontal rate
as it probably puts more stress on the components than the vertical rate.
I have found that as you approach the upper limits, there is a good chance
that the geometric accuracy of the raster near the top of the screen may
start to deteriorate due to lock in problems as well.  However, it would be
foolhardy to depend on this sort of behavior as an indication of going over
the edge.
It will be much too late when you find out.  If the manual says 75 Hz V and
64 KHz H, stay below **both** of these.  If you exceed the safe ratings and
the design isn't really good, there is the possibility of blowing components
in the horizontal deflection and high voltage sections which will result in
expensive repair bills.  You will likely get no warning of impending failure.
In addition, even if the monitor does not immediately turn into a pile
of smoking silicon and plastic, components may be under more stress and
running at higher levels of power dissipation.  Total failure may be just
around the corner.  More subtle degradation in performance may occur over
time as well.
You won't see the difference anyhow beyond 75 Hz and your programs may
run slightly faster at lower refresh rates since the video is not using
as much bandwidth (however, the difference here may be very slight or
non-existent depending on your board, computer, applications, etc..
  9.6) Picture squeezed in then died
You were happily playing 'Doom' when the sides of the picture squeezed in two
inches or so when the entire monitor went dead - has remained like this since.
Sound is fine, but no activity at all from the tube.  Has it died?  How
much time, effort, and expense to fix?
No, it's not dead, at least it certainly is not the picture tube.
Your probably shot the monitor instead of the bad guys!
Is there any indication of light on the screen?  Any indication of the
horizontal deflection running at all as evidenced by static on the screen?
In any case, there is a problem in the horizontal deflection and you probably
have no high voltage as well assuming no light on the screen.
The fact that it squeezed in first indicates that a partial short or other
fault may have developed in the horizontal deflection circuits - possibly
the deflection yoke or flyback transformer.  It could also have been a bad
connection letting loose.  Once it failed completely, the horizontal output
transistor may have bought the farm or blown a fuse.
  9.7) Horizontal deflection shutting down
Confirm that the horizontal deflection is shutting down (along with the
high voltage since it is derived from horizontal deflection: listen
for the high pitched deflection whine (NTSC/PAL/CGA), test for static on
the screen, see if the CRT filaments are lit, turn up the brightness and/or
screen control to see if you can get a raster) and then why:
1) Power is failing to the horizontal output transistor - this could be
   due to a low voltage power supply problem, bad connection, etc.
2) Base drive to the horizontal output transistor is failing - could be a
   fault in the horizontal oscillator or bad connection.
3) Problem with the flyback transformer or its secondary loads (flyback
   may provide other power voltages).
4. X-ray protection is activating - either due to excess HV or due to a
   fault in the X-ray protection circuitry.
If the problem comes and goes erratically it sounds like a bad connection,
especially if whacking has an effect.  If it comes and goes periodically,
then a component could be heating up and failing, then cooling, etc.
  9.8) Horizontal squashed
A very narrow picture may indicate problems with the power supply to the
horizontal deflection circuits, incorrect scan rate selection or defective
components, faulty deflection yoke, or bad connections.
If the size is erratic and/or gently whacking the monitor makes the width
change, bad connections are likely.  See the section: "Monitor manufacturing quality and cold solder joints".
Confirm that your video card is running at the proper scan rate - particularly
that it is not violating the monitor's specifications.  An excessive horizontal
scan rate is a common cause of a reduced width raster.  Try its software
setup adjustments as these may have been lost.
Beyond this, a schematic will probably be needed to isolate the fault.
  9.9) Monitor non-linearity
Most modern monitors are nearly perfect with respect to non-linearity.
There almost never any user adjustments and there may not even be an
internal adjustments.  See the section: "Position, size, and linearity adjustment".
A sudden change in linearity or a monitor that requires a warmup period
before linearity becomes acceptable may have a bad component - probably
a capacitor in the horizontal deflection circuits.  For the latter, try
some cold spray or a heatgun to see if you can locate the bad part.
(From: helio (mmccann@usa.pipeline.com)).
You should likely begin in the area immediately around the HOT, perhaps
there might be a high frequency NP (non polarized) electrolytic just
starting to go. Some larger monochrome monitors actually have working H-lin
adjustment coils (believe it or not) especially if they are older ones. But
most are glued/potted down or fixed value. If you locate it (the coil) the
problem should be nearby.
  9.10) Picture squeezed on both left and right side of screen
"I'm trying to repair a Target DN-1564 monitor with a problem in the
 horizontal deflection: on both the left and right side of the screen
 the picture gets squeezed together, regardless of H-width and other
 settings. I've checked most semiconductors in this part, but I can't
 find anything wrong there."
This sounds like an S-correction capacitor may have too small a value or
failed open.  Check the capacitors in the vicinity of the deflection yoke
connector and HOT.  It could be due to bad connections as well.
S-correction is needed to linearize the horizontal scan (and vertical as well
scan but that is a separate circuit).  Without S-correction, the scan current
would be nearly linear.  This would result in greater coverage in a given
time near the edges of high deflection angle CRTs.  The picture would appear
stretched near the edges  In this case, the correction appears excessive.
(From: David Henniker (david.henniker@cableinet.co.uk)).
I had a similar problem with a monitor (here in Edinburgh Scotland).
The S-correction cap was open-circuit altogether. Other caps in parallel
allowed the distorted scan. If it had been a TV there wouldn't have been
other caps in parallel and the result would have been no line scan, maybe
a vertical line (line collapse) or nothing at all.
  9.11) Vertical squashed
This means the vertical size is reduced with or without distortion.
Before attacking the circuitry, make sure your vertical scan rate is within
the monitor's capabilities and that the user vertical size control is adjusted
properly.  If there is no distortion, this is likely as many (but not all)
circuit problems would result in non-linearity or cutoff of the top or bottom
portions of the picture.  All you may need to do is change your computer's
video settings!  Swap the monitor or computer to be sure it is not a problem
with the video card.
However, if failure happened suddenly and the vertical is squashed at all scan
rates, this is likely a vertical deflection problem - possibly a bad capacitor,
bad connection, bad flyback/pumpup diode, or other component.  None of these
should be very expensive (in a relative sort of way).
If the symptoms change - particularly if they become less severe - as the unit
warms up, a dried up electrolytic capacitor is most likely.  If they get
worse, it could be a bad semiconductor.  Freeze spray or a heat gun may be
useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in
the vertical output circuit.  Look for bad connections (particularly to the
deflection yoke), then consider replacing the vertical output IC or
transistor(s).
A defective deflection yoke is also possible or in rare cases, a bad yoke
damping resistor (e.g., 500 ohms, may be mounted on the yoke assembly itself).
The following are NOT possible: CRT or flyback.  I am just trying to think of
really expensive parts that cannot possibly be at fault :-).
  9.12) Keystone shaped picture
This means that the size of the picture is not constant from top to bottom
(width changes) or left to right (height changes).  Note that some slight
amount of this is probably just within the manufacturing tolerance of the
deflection yoke and factory setup (geometry magnet placement, if any).  With
a monitor, such defects are more noticeable than with a TV since much of the
display is of rectangular boxes - i.e., windows, lines of text, graphics, etc.
Furthermore, the monitor is usually run just barely underscanned to maximize
the viewing area without cutting anything off.  Any deviations from perfection
show up in relation to the CRT bezel.
However, a sudden increase may indicate a problem with the deflection yoke.
An open or short in a winding (or any associated components mounted on the yoke
assembly) will result in the beam being deflected less strongly on the side
where that winding is located.  However, with a high scan rate monitor, there
may be many individual windings connected in parallel in the yoke so the effect
of only one opening up may not be as dramatic as with a TV where there may only
be a single pair of windings for the horizontal and another for the vertical.
A simple test of the yoke in this case can be performed by simply swapping
the connections to the yoke for the affected direction (i.e., if the width
changes from top to bottom, interchange the connections to the vertical
windings).
* If the keystone shape remains the same (but of course the picture flips),
  it is likely the yoke.
* If the keystone shape flips, it is a circuit problem (see below).
See the section: "Deflection yoke testing".
If the monitor has been dropped off a 20 story building, the yoke may have
shifted its position on the neck, of the CRT resulting in all sorts of
geometry and convergence problems (at the very least).
(From: James Poore (aw133@lafn.org)).
I have seen the 'reverse keystoning' in several monitors and the fix is
usually the same.  In the horizontal leg of the pincushion transformer are 1
or more electrolytics to ground.  The caps have + going to transformer and -
to ground.  Anyway when they start loosing capacitance and/or become leaky the
reverse keystoning effects become more pronounced.
  9.13) Picture size changing
If the picture area is expanding or contracting without any changes to your
video card settings or other software. then there is a problem with the power
supplies in the monitor.  This would be confirmed if the change is (1) gradual
over the course of say, an hour, and/or (2) gently whacking the monitor has
some effect indicating bad internal connections.  Software problems would not
result in either of these characteristics.
Note that if the change is very small - say, less than 1 or 2%, then it may
simply be normal for your monitor due to poor design or the use of inferior
components - some parts associated with power supply regulation may be
changing value as the monitors warms up.
A way to confirm that something is drifting due to thermal problems would
be the monitor from another computer and see if the same thing happens.
Just powering the monitor by itself (but not in any power saving mode) might
also work for this test.
One possible cause could be that the high voltage is drifting gradually
due to a faulty component - increasing and making the beam 'stiffer' or
vice-versa.  If this is the case there might also be a gradual change in
brightness as well (decreasing image size -> increase in brightness).
Alternatively, the HV may be stable but the power to both H and V deflection
is gradually changing.
Excess high voltage can increase the X-ray emissions and any kind of power
supply problems may ultimately result in total failure and an expensive
repair.  Therefore, these symptoms should not be ignored.  See the sections
on low voltage and high voltage power supply problems.
  9.14) Monitor will not sync
For monitors using BNC cables, first make sure that the cable connections
are correct - interchange of H and V sync or G with one of the other video
signals (sync-on-gree setups) can result in all kinds of weird sync problems.
There are a wide variety of causes for a monitor that will not display
a stable or properly configured image.  Among the symptoms are:
* Lack of sync horizontal - drifts smoothly horizontally.  This may mean
  that the horizontal sync signal is missing due to a bent, pushed in,
  or broken connector pin (pin 13) or other bad connection or a fault
  in the sync processing circuitry.
* Incorrect lock horizontal - torn picture (like a TV with the horizontal
  hold control misadjusted - if you remember these).  This means that the
  sync signal is reaching the monitor but that it is having problem locking
  to it.  Check the rate specifications - you may be exceeding them.
* Lack of sync vertical - rolls smoothly vertically.  This may mean
  that the vertical sync signal is missing due to a bent, pushed in,
  or broken connector pin (pin 14) or other bad connection or a fault
* Lock not stable vertical - jumps or vibrates vertically.  This may be
  due to scan rate problems or a fault in the vertical sync circuitry of
  the monitor.
* Multiple or repeated images horizontally or vertically.  There may be
  multiple images side-by-side, on top of each other, or interleaved.
  Most likely cause is driving the monitor with an incorrect scan rate.
  However, faulty circuitry could also be to blame.
Additional comments on some of these problems follow in the next few
sections.
  9.15) Horizontal lock lost
A monitor which loses horizontal lock when changing resolutions, momentarily
losing the signal, or switching inputs may have a horizontal oscillator
that is way out of adjustment or has drifted in frequency due to aging
components.  Alternatively, you may be running at scan rates that are not
supported by your monitor.  Check its user manual (yeh, right, like you
have it!).  Use the setup program that came with your video card to adjust
the default scan rates to match the monitor.  Not only will it lock better,
you are less likely to damage the monitor by feeding it improper scan rates.
Note that the characteristics of this are distinctly different than
for total loss of sync.  In the latter case, the picture will drift sideways
and/or up and down while with an off frequency oscillator, the torn up
picture will try at least to remain stationary.
Assuming you are have your video card set up properly - double check anyhow -
this could be a capacitor or other similar part.  Or, the oscillator
frequency may just need to be tweaked (particularly with older monitors).
There may be an internal horizontal frequency adjustment - either a pot
or a coil - which may need a slight tweak.  If a coil, use a plastic
alignment tool, not metal to avoid cracking the fragile core.  There may
be several adjustments for auto-scan monitors - one for each major scan
range.
A schematic will be useful to locate the adjustment if any or to identify
possible defective parts.  If it is a heat related problem try cold spray
or a heat gun in an effort localize the offending part.
  9.16) Insufficient width (without hum bars)
If there are hum bars or wiggles in the picture, see the section: "Reduced width picture and/or hum bars in picture".
If both width and height are affected, the cause is likely something common:
low, low voltage power supply voltages or excessive high voltage (resulting
in a 'stiffer' beam).
(From: Jerry G. (jerryg@total.net)).
Lack of width is usually caused by defective power supply, low horizontal
drive to the yoke and flyback, defective circuits in the pincushioning
amplifier section, excessive high-voltage caused by defective voltage
regulation, and or excessive loading on the secondary side of the flyback.
  9.17) Loss of horizontal sync (also applies to vertical) after warmup
The problem lies either in the horizontal oscillator or in the sync system.
If it really is a problem with sync pulses not reaching the oscillator,
the picture will move around horizontally and can be brought to hold
momentarily with the hold control. If the picture breaks up into strips,
there is a problem in the horizontal oscillator.  If there is an accessible
hold control try rotating it: if the frequency is too far off, the picture
will not settle into place at any adjustment of the hold control. Look
around the horizontal oscillator circuit: all of the oscillator parts will
be right there, or check on the horizontal oscillator module.  If only
one resolution on a auto-scan monitor is affected, the there could be a
separate oscillator circuit for each range.
  9.18) Replicated or offset multiple images
Multiple images on the screen horizontally or vertically indicate that
the scan rate is way off (by a factor equal to the number of complete
pictures.)  This could be a fault in the monitor or you could be running
way outside of the monitor's specifications.  Even slightly exceeding
these for the horizontal or vertical may confuse the scan rate selection
logic and result in the monitor setting itself with incorrect scan rate
settings.
A situation where successive sweeps alternate position slightly resulting
in double or triple images may be caused by a incorrect or out of range
video timing, a bad component, or improper sync signals.
Check the settings of the video card and any sync termination or selection
on the monitor.  Beyond this, a schematic will be required.
  9.19) Part of picture cut off
The following applies if the part of the picture is missing but not
otherwise squashed or distorted.  For example, 85% is missing but the
portion still visible is normal size.
Wow! That's an interesting one, more so than the typical run-of-the-mill
"my TV just up and died on me".  Or, "my pet orangutan just put a hole
in the CRT, what should I do"?
With a monitor, this is more likely than a TV.  But the cause is probably
not in the monitor (though not impossible).  Check that your video parameters
are set up correctly (particularly if you have full control of them as with
Linux).  You may have set the active too short or blanking too long.
If your video is confirmed to be ok (looking at it with an oscilloscope would
be best), then with the size of the picture fragment correct but 85% missing,
check waveforms going into the vertical output stage.  The supply voltage is
probably correct since that often determines the size.  It almost sounds like
the waveform rather than being mostly on (active video) and off for the short
blanking period is somehow only on during the last part of the active video
thus giving you just the bottom of the picture. If there is a vertical output
IC, it may be defective or the blanking input to it may be corrupted.  The
problem may be as far back as the sync separator.  Then again who knows,
schematics would be really handy.
  9.20) Bright or dark bars on edge of picture (horizontal or vertical)
These may be sharp-edged or blurry.  The latter could result when a portion
of the active video is unblanked during retrace.
* Where the entire picture is present, the problem is one of the video
  blanking not occurring properly beyond the picture boundary.
* Where part of the picture is cut off with a bright horizontal or vertical
  line at that point, it is either a video timing problem or a fault in the
  deflection circuitry preventing the beam from being where it is supposed to
  scan in enough time.
  You may be seeing part of the active video during retrace or as the beam
  reverses direction at the start or end of retrace.  Horizontal timing
  problems would produce vertical bars on the right or left edge; vertical
  timing problems would produce horizontal bars at the top or bottom edge.
* If your video card permits control of video timing parameters, try reducing
  the relevant active time relative to the blanking period.  The relevant
  software settings might be horizontal position, phase, size, and sync
  polarity.  If this does not work, your video card may be incompatible with
  the monitor.
* If the problem just happened without any changes to the video source, the
  monitor may have a problem:
  - Deflection circuits - coil or capacitor, a power supply fault, position or
    size settings or control, or deflection yoke.
  - Video amplifier or drive (CRT neck board), or blanking circuits - chip
    decoupling capacitors or filter capacitors in scan derived power supplies.
    If the bars are significantly colored - not just shades of gray - then
    a video problem is likely.
An oscilloscope would help greatly in identifying the source of the problem.
