Construction Guidelines for Basic Quadrature-Sin-Cos Decoder and Quad-A-B Interface Kits
Version 1.01 (28-Jun-2022)
This manual provides instructions for the construction of a quadrature-sin-cos decoder and simple interface to quad-A-B for µMD0 or µMD2. While the optical parts (including the photodiodes) are capable of many MHz, the electronics at this point are very rudimentary. Someday this may change but for higher performance, a user-supplied (or designed) dual pre-amp and interface will be required. Schematics for two possibilities are included below.
Versions of these kits are presently available through my eBay listing for µMD0.
There are presently two available kits, the "Quadrature-Sin-Cos decoder" with or without the "Interface to µMD0 or RS422" (including µMD0). (For more information on µMD0 and more, see the links on Sam's Electronics and Laser Kit Information and Manuals page.
  1. Quadrature-Sin-Cos decoder: This takes the output of an interferometer, encoder, or other source of signals in a similar format and converts it to electrical signals phase-shifted by 90 degrees.
    Rotary Encoder Digital Signals as a Function of Orientation
    This shows a rotary optical encoder which uses a pair of LEDs and photodiodes physically offset by 90 degrees to generate Quad-Sin-Cos analog signals which are then thresholded to yield Quad-A-B digital signals. The specific type of sequence is called a "Gray" code (not based on color but attibutable to someone named Frank Gray) and has the property that any possible allowable change in value is a change in only a single bit. This eliminates the ambiguity with sensors using the normal binary order where two bits can change at not quite the same time.
    (The annimated graphic seems to be all over the Web. If anyone knows who the original copyright holder is, I will acknowledge them.)
    An interferometer with angled paths for the two interfering beams produces fringes similar to the pattern of an optical encoder so a quad detector could be built with offset photodiodes and this has been done in some ring laser gyros as well as stabilized HeNe lasers. However, more commonly, the 90 degree phase shift is done optically using a single combined beam as shown below. The Quarter WavePlate introduces a 90 degree phase shift. If resulting Quad-Sin-Cos analog signals are thresholded and converted to digital form, the result would be a Quad-A-B format.
    This shows variations on one of several common implementations for a Quad-Sin-Cos decoder that provides Sine and Cosine outputs for use in a displacement measuring system. This is among the simplest. In most instances, the photodiodes would be reverse biased to provide a linear response. Commercial systems will generally have a third "Intensity" channel to compensate for variations in detected power due to the laser aging, changes in alignment, and contamination over time. The Intensity channel can be implemented electronically or optically with a non-polarizing beam-splitter at the input and additional photodiode.
    The purpose of the angled arrangement is to minimize the difference between the amplitudes of the two polarizations. Otherwise, with 45 degrees being close to the Brewster angle (around 57 degrees), one will be much larger than the other. Even so-called 50:50 beam-splitters may be subject to this, so using the angled arrangement for either one may be beneficial. There is an Attenuator Plate (AP) in these kit, which simplifies construction. Using the AP also permits the relative amplitudes of the Channel A and B signals to be mostly balanced without electronic adjustments.
    The signal outputs from the biased photodiodes will be analog and close to sinusoidal. The relative phase shift betweem the A and B channels will be determined by the construction of the encoder or interferometer and the direction of motion. The graphic belows shows the specific case of a displacement measuring interferometer:
    Typical Quad Decoder Signals as a Function of Time and Displacement Direction
    (Scope Triggered on Rising Edge of Channel A Signal)
    The photo shows the typical optical parts and photodiodes. The basic detector using a single photodiode like the DET110 can generate a signal corresponding to light and dark fringes, but cannot provide direction information, essential for using an interferometer in metrology applications. The Quad-Sin-Cos decoder provides a pair of outputs that are 90 degrees offset from each-other in position, similar to the outputs of a rotary or linear encoder:
    Quadrature Detector using Variable Attenuator Plate and Circular Polarizer Sheets: Optical Layout, Parts, Built on Solderless Breadboard, Protoboard, and PCB
    The ugly scope screen shots below shows behavior which is close to perfect:
    Channel A and B Signals with Positive (Left) and Negative (Right) Displacement
    Capturing a decent photo while twiddling the micrometer screw is quite challenging. ;-) But the conclusions are clear: This simple Quad decoder does its job well with a phase shift of close to ±90 degrees. If the Arm 2 mirror or retro-reflector were on an electronically controlled positioner like a loudspeaker voice coil or linear motor driven with a ramp, the waveforms would be textbook quality. ;-) With only a small stretch of the imagination, it can be seen that the screenshots agree with the expected behavior based on the diagrams, above. OK, perhaps not such a small stretch. ;-)
    A prototype was constructed, appropriately enough, on a prototyping board :), and then the simple PCB was made so that mounting of the photodiodes and other electrical components would be simplified. There is nothing to really secure the AP/BS but that could be done with double-sided tape. Later the version using a small solderless breadboard was built and that version is the default for these kits since it does not require any soldering.
    The mounting scheme doesn't need to be fancy or pretty but should hold the pieces securely while maintaining alignment. This can use bits of tape and Epoxy or other adhesive. The CPs (QWP/LP and LP) are expendible so feel free to chop them up if necessary to fit. :)
    The photos above show various possibilities not involving a 3-D printer :), including a minimal custom PCB, but some soldering is required for that. The simplest approach is to use a small Solderless BreadBoard (SBB) which has a double sided sticky pad on the bottom which enables it to be attached to a standard optical post or other support.
    Quadrature Decoder Constructed on Small Solderless Breadboard
    1. Set up the HeNe laser so that there is a linearly polarized beam. Orient the polarization to be at 45 degrees or preferably, the output of the interferometer as well.
    2. Mount the AP at an angle as close to normal to the incident beam as is convenient to still be able to locate the Channel B CP and PD in the reflected beam. The rational for this is to minimize the effect of the angled plate on the polarization of the reflected and transmitted beams. Why? If you're into fancy 3-D-printed mounts, it can be arranged to use the screw/spring combination to adjust it's position, and thus attenuation (or transmission and reflection). But that certainly is not required and the screw and spring can be relegated to your junk drawer. ;-)
    3. Mount one PD to intercept the transmitted beam. (This will be designated Channel A or 1.) Trim the leads if necessary so that in conjunction with adjusting the height of the platform, the beam can be approximately centered vertically in the AP.
    4. Adjust the position of the AP so that the transmitted and reflected beam intensities are approximately equal. This will be near or at the higher-density end of the AP. If perfect balance is not possible, the remaining adjustment will need to be done with the Gain trim-pots (substituting for the fixed resistors, or later when the interface circuit is built).
    5. Install the second PD (Channel B) to intercept the reflected beam. Note that the AP glass is slightly tilted so it may be necessary to trim the PD's leads or bend them over so its height will be correct.
    6. The PDs should be reverse biased with 5 to 15 VDC (+ to cathode, the right leg facing front). A load resistor of approximately 100K ohms should result in a decent signal amplitude for a ~1 mW laser. If too high or too low using only the laser, no need to change until using the actual interferometer output. 100K ohm trim-pots are included in the kits for this purpose. The typical wiring for a two channel biased photodiode is shown below.
             R-Protect       PD1         Yellow
         +-----/\/\----+-----|<|------<<----------------+-----------o Channel A
         |    1K ohms  |                                |
         |             |     PD2         Blue           |
         |             +-----|<|------<<--------------------+-------o Channel B
         |          Facing Front of PDs                 /   /
         |           with Legs Down -           R-Load1 \   \ R-Load2
         |            Anode: Left Pin       10K typical /   / 10K typical
         |           Cathode: Right Pin                 \   \
         |                                              |   | Black
         |                                              +---+-------o Ground
         |                                    DC Power  |
         |                               Red   +| |-    |
         |<-- Solderless Breadboard -->|<-- Output / Power Wiring -->
    (Should you care, the yellow and blue wire colors correspond to the channel 1 and 2 trace colors for the FNIRSI 1013D tablet scope used for testing.)
    In the photo, above, one piece of CP sheet is stuck directly to the channel 1. PD. The other piece of CP sheet is simply propped in front of the channel 2 PD with the sticky side facing out. Long term, that side should be protected with some 5 Minute Epoxy or a microscope cover slip. The AP is just sitting on the SBB. Dabs of 5 Minute Epoxy, wire loops, or other means can be used to secure them more permanently. If using wire loops, take care not to short out anything that shouldn't be connected. ;)
    1. Cut a pair of 0.5x0.5cm or larger pieces of the CP sheet aligned with the original edges.
    2. Carefully remove the protective film from both sides of the cut pieces. One side is simply bare plastic; the other side has a sticky adhesive.
    3. The adhesive-side of the CP is the QWP with its optical axes at 0/90 degrees (aligned) with the edges; the other side is the LP with its axis at +45 or -45 degrees. This can be confirmed by testing with a linearly polarized laser or a random polarized laser with a separate linear polarizer in front of it:
      • When the CP's LP-side faces the laser, rotating it will result in the transmitted intensity going very close to 0.
      • With the CP-side facing the laser, there will be little or no change in intensity.
    4. Channel A: Attach the adhesive side of one of the pieces of CP directly to the front of the Channel A PD making sure to keep it aligned with the horizontal and vertical axes. This will result in its LP-side facing the AP oriented so the polarization axis is at 45 degrees (edges aligned with the X and Y axes). The result should be a strong signal as the position of the remote reflector is changed using a micrometer stage or whatever is convenient to change the the Path Length Difference (PLD).
    5. Channel B: Attach the other piece of CP in the reflected beam so that its QWP-side faces the AP and is oriented at 0/90 degrees (edges also aligned with the X and Y axes). This is best done by using a drop of 5 Minute Epoxy to stick it directly to the Channel B PD, but if large enough, it can just be placed in front of the PD with a wire loop or something similar to stabilize it. Just make sure that the wire loop doesn't short out something important. ;) The result should be a strong signal as the PLD is changed. Once correct behavior is confirmed, coat the adhesive-side with a thin layer of 5 Minute Epoxy to prevent it from attracting contamination like dirt and dust, or stick it to a microscope cover slip. The original protective film messes with the polarizatioin (it acts as a waveplate of some sort) so it is not suitable.
    6. Fine tune interferometer alignment to maximize signal amplitude and adjust the values of the PD load resistors so that the signal amplitudes are between 3 and 5 V p-p.
    7. Observe the Channel A and B signals on the oscillscope. They should be in quadrature (or very close). This means the phase shift between them should flip from +90 to -90 degrees depending on the direction of motion as in the diagram and photos, above.
    More on all this below in the section on displacement measurement.
    Quad-Sin-Cos Decoder Parts List
      Prt#  Description
      SBB1  Solderless breadboard with 170 tie points (17x2x5)
      PCB1  Quad Decoder PCB (optional with µMD0 PCB only)
      AP1   Variable attenuator plate used as adjustable NPBS
      CP1*  Piece of Circular Polarizer (CP) sheet (axes ±45 degrees, cut to size)
      LP1*  Piece of Linear Polarizer (LP) sheet (axes 0/90 deg, cut to size)
      CS1+  Microscope cover slips (round or square, 2 or 3, if included)
       R1   PD protect resistor
       C1   Bias bypass capacitor
      PD1   Photodiode for Sin/A channel
      PD2   Photodiode for Cos/B channel
      SKT1  Male-female 2 pin socket for PD1
      SKT2  Male-female 2 pin socket for PD2
      STB1  4 pole screw terminal block
    * Only a CP sheet may be included. In that case, a piece of it will act as a QWP if the sticky side faces the PD; it will act as an LP otherwise.
    + The purpose of the microscope cover slips is to be able to attach the QWP (adhesive)-side of the CP to a clear window to prevent dust and fingerprints from building up on the adhesive, and the glass won't mess with the polarization. Being thin and fragile, avoiding them if at all possible is desirable. ;-) Where that side of the CP faces a PD, it can simply be stuck to it directly. ;-) Elsewhere, a thin layer of 5 Minute Epoxy can serve the same purpose.
  2. Interface to µMD0 or RS422: These are basic circuits that converts the output of the photodiodes to Quad-A-B TTL or RS422 signals. As shown, the performance is low - thousands of counts per second affected by the settings of R1 and R6 and other component values. For higher bandwidth, trans-impedance amplifiers will be required and possibly a faster voltage comparator. That is left as an exercise for the student with this simply being a way to get started. These slow speed versions can be built on a small solderless breadboard as shown below. The photo of the circuit on the solderless breadboard is virtually identical to the schematic:
    Quad-Sin-Cos Interface to Atmega 328P Nano 3.0/µMD0 Schematic (Left), on Solderless Breadboard (Center), using Custom PCB (Right)
    If using the Solderless BreadBoard (SBB), Parts placement is not at all critical but making it "nice" will help especially if problems are found. Standard Arduino-style male-male jumper wires can be used where necessary, but should be replaced eventually with suitable lengths of #22-#24 AWG solid wires. DO NOT force larger wires or stranded wires into the holes as the spring contacts may be damaged, leading to unreliable connections.
    And for the uninitiated, there are two types of busses on the 400 tie point (and other larger) SBBs. A pair of busses all the way across the top and bottom are generally used for power and/or ground connections though there is no law about that. The remainder are 25 pairs of vertical busses with 5 tie points each.
    If using the SG-uMD0 PCB, go to Assembly Instructions for the SG-µMD0 - RS422 and Analog Inputs.
    Basic Quad AB Interface Parts List
    Here is the very long detailed parts list for driving a TTL-compatible device like µMD0. :) The numbering refers to schematic above. This does not include the additional parts on the SG-µMD0 PCB for interfacing to RS422 or for interfacing to µMD2:
      Prt#  Description                 Comments
       U1   LM393P, 8 pin DIP           Dual voltage comparator
       C2   0.1 µF capacitor            Power supply bypass for U1
      LED1  LED, red                    Thresholded Sin, A
      LED2  LED, HB green               Thresholded Sin, B
       R0   Resistor, 1K                Photodiode protection
       R1   Trim-pot, 100K-200K         Sin (Channel A) load resistor*
       R2   Trim-pot, 10K               Sin (Channel A) threshold
       R3   Resistor, 100K              Sin (Channel A) trim-pot isolation
       R4   Resistor, 470K              Sin (Channel A) hysteresis
       R5   Resistor, 2K-2.2K           Red LED current limiting
       R6   Resistor, 1K                Channel A pullup
       R7   Trim-pot, 100K-200K         Cos (Channel B) load resistor*
       R8   Trim-pot, 10K               Cos (Channel B) threshold
       R9   Resistor, 100K              Cos (Channel B) trim-pot isolation
       R10  Resistor, 470K              Cos (Channel B) hysteresis
       R11  Resistor, 36K-47K           Green LED current limiting
       R12  Resistor, 1K                Channel B pullup
      SBB1  Solderless breadboard with 400 tie points
    R1 and R6 can serve as load resistors for the photodiodes (as shown) if bandwidth is not critical, or as the feedback resistors for proper trans-impedance amplifiers. R0 is simply to protect the PDs should they be installed backwards, and the power supply should a PD fail shorted.
    Most of these parts are also included in the kit for µMD0, which includes a solderless breadboard as well. A similar circuit on a solderless breadboard is shown below.
    This version doesn't have the two trim-pots R1 and R7. To make space for them, the other parts can be moved 4 holes to the right.
    And here is a version to interface directly to the Teensy used in µMD2:
    Note the 3.3 V source from the Teensy for the output pullups. This is critical to the health of the Teensy. Higher voltage (i.e., 5 V) may damage it.
    And finally here is a version to generate RS422 for use with SG-µMD2 or other compatible device:
    Additional parts for RS422 Output:
    These would be needed to drive the RS422 inputs of µMD2 in the normal way. Alternatively, the components for the threshold can be installed on µMD2 so that the inputs can be single-ended. Information is in the Assembly Instructions for the SG-µMD2 Version 1.22 PCB. The only disadvantage of this approach is that to use µMD2 later with RS422 inputs may require removing the threshold connection to the input pin(s).
      U2   UA9638, 8 pin DIP           Dual RS422 line driver
      C3   0.1 µF capacitor            Power supply bypass for U2
  3. Schematics of higher bandwidth front-ends: Here are three circuits that can at least be use as starting points to design and/or construct systems with count rates of 1 MHz or more. (Click on the image for the full resolution version.)
    The first is/was used by Teletrac for their single frequency laser-based systems.
    In addition to the Sin and Cos channels, it also has an Int (intensity) channel which adjust the offset to accomodate varying signal levels.
    The second is a circuit for which I am contemplating designing a PCB but it may not happen for awhile.
    It's a combination of a dual trans-impedance pre-amp, gain stage, threshold to convert to Sin-A-B, and RS422 line drivers.
    The third will be a simple PCB that accepts the two optical inputs and outputs RS422. So it should be a straightforward solution not requiring high speed op-amps. Its bandwidth is greater than 3 MHz with an optical power below 25 µW.
