Notes on the Troubleshooting and Repair of
Small Gasoline Engines and Rotary Lawn Mowers
Version 2.07
Copyright © 1994-2001
For corrections/comments/suggestions, please contact me via the Sci.Electronics.Repair FAQ Email Links Page.
  • Back to Small Engine Repair FAQ Table of Contents.
    Improper use, testing, or repair of gasoline powered equipment can result in explosion, fire, injuries including loss of limbs or worse, as well as total destruction of your spouse's prized flower bed.
    We will not be responsible for damage to equipment or property, your ego, or personal injury or worse that may result from the use of this material.
    Can you see above the weeds?
    Most problems with gasoline powered rotary lawn mowers as well as other small engines have simple and inexpensive solutions. For example:
    This document addresses some of the most common ailments and provides detailed instructions for their diagnosis and cure. In addition, it provides detailed maintenance guidelines to prolong the life and happiness of your lawn mower(s) and other yard equipment.
    For electric lawn mower and other electric yard tool problems, refer to the document: Notes on the Troubleshooting and Repair of Small Household Appliances and Power Tools which includes chapters on basic electrical theory (relax, no rocket science) and electric motor testing and repair information.
    We will deal with problems the weekend gardener is likely to run into (sometimes, literally!) as well as semi-detailed overhaul instructions. One or more of the books listed in the section: References can be used to supplement this document and can provide much more detailed troubleshooting and repair procedures.
    Even if you don't know the difference between a carburetor and a crankshaft, you may still be able to do some of your own work. (Hint: if you drop one of these on your foot, the crankshaft will hurt a lot more!) We begin with an introduction to small engine technology and have more-or-less separate chapters on basic maintenance, intermediate troubleshooting and repairs, and more extensive overhaul procedures.
    I welcome comments, additions, hints, corrections, funny or other stories, etc. As the title implies, it is oriented toward the gasoline engine powered rotary lawn mower. However, much of the general information applies to a wide range of yard and shop equipment powered by small 2 and 4 stroke gasoline engines.
    Despite all the dire warnings (don't forget that the lawyers need to make a living!) it is possible to use, store, maintain, and repair gasoline powered equipment safely. Mostly, the necessary precautions are just common sense - for example, don't smoke around gasoline (well, don't smoke at all but that is not a part of the charter of this document!).
    The following represent the basic precautions to take when performing maintenance or service procedures on gasoline powered equipment and dealing with gasoline in general:
    Tools and supplies
    While you probably did not purchase your lawn mower specifically for the joys of repairing it, there is always a chance that despite all your precautions, the blade will strike a rock that just happened to grow out of the ground when you weren't looking. Therefore, it makes sense to be prepared.
    Basic servicing of small engines doesn't require a $500 tool caddy. However, some basic hand tools and other items will be needed.
    Lawn Mower Basics and General Maintenance
    Gas, electric, or manual?
    Many people who have never used a gasoline engine powered piece of yard equipment are intimidated by all the warnings with respect to the explosive nature of gasoline. They then opt for an electric lawn mower instead of gas. For many, this is the correct choice. There are a different set of precautions to follow but they are fewer and seemingly less of a threat.
    Electric equipment is in some ways more environmentally friendly generating no pollution (though the electricity had to generated somehow). Once the equipment is unplugged, there is nothing to worry about with no gasoline to store. Little maintenance is needed and there is never any issue of disposing of used engine oil - since there is no engine oil. Electric equipment is also usually - though not always - somewhat quieter.
    The main disadvantage of line powered electric equipment is that it is tethered to an electric outlet by the power cord. This can become quite a nuisance after a short while. Battery powered equipment has tended to less powerful and more finicky to deal with than similar equipment powered from a line cord. And, electric mowers tend to be less powerful than similar equipment using a small gasoline engine.
    Where your yard is relatively small (say, less than 50 feet to an electric outlet from the farthest point), a corded mower may be a good choice. It will be less expensive than typical battery powered mowers and most gasoline powered mowers, and vitually maintenance-free. Just make sure you use a proper outdoor heavy duty extension cord - probably one size LARGER (lower AWG wire size number) than what the manufacturer recommends. This will assure minimal loss of voltage due to its resistance - and every bit of power you have available will help! A somewhat lighter duty outdoor cord can be used for the first few feet if that makes maneuvering the mower easier. The main thing to watch out for is accidentally cutting the cord by running over it. Mowing in a back-and-forth pattern while moving away from the outlet helps. If you do cut the cord - don't panic. At most, you will need to shorten it a couple of feet and install a new socket on the end of what is left AFTER pulling the plug! If the outlet is now dead, at most you have tripped the circuit breaker or GFCI, or blown the fuse. Of course if you make a habit of this, your cord could get to be quite short. :-)
    Battery powered yard equipment and power tools have improved greatly over the years. Some of the newer models are quite capable of cutting a modest size yard (e.g., 1/4 acre, manufacturers specifications may still be a bit optimistic) on one charge with ample power for moderately thick grass. But, there is quite a bit of variability in cutting performance and battery life so shopping around, consulting Consumer Reports, and making sure you get a return option if you are not satisfied are all well worth the effort - to save effort in the long run.
    It is interesting, however, that quite capable battery powered tractors for example, have been around for a long long time.
    See the section: Comments on electric mowers for more information.
    Having said all that, the fact of the matter is that the vast majority of lawn mowers used for modest or larger lots are gasoline powered.
    Of course, if you have a postage stamp size or even a small suburban lot, a manual reel mower may be your best choice - and you get some good exercise as part of the deal as well.
    Also see the comments in the Chapter "Items of Interest" on electric and manual mowers.
    Types of lawn mowers
    Depending on the size of your lot, glowing conditions, and your energy level, one or more of the following options will fit you like a glove: The first two of these are described in more detail is subsequent sections of this document. For the last, well you should already know if that is appropriate for your life-style!
    Large mowers (those which carry you) may be of either the rotary or reel type, usually gasoline or diesel powered but some electrics have been produced. For information on riding mowers, lawn tractors, garden tractors and estate tractors (also known as compact diesel tractors), see the Small Tractor FAQ.
    Consumer Reports regularly provides reviews and ratings of most common types of lawn mowers. These articles are a good place to start as they include a great deal of the basic information needed to decide on the lawn mower type best suited for your property. They compare a selection of typical models based on features, safety, price, and their tests of performance and operator convenience. If you do not subscribe to Consumer Reports, your local library will likely have access to several years of back issues.
    For even more advice, see Consumer Reports Books' Yard and Garden Equipment Buying Guide. It is sold at bookstores and newsstands and is also available directly from Consumer Reports Books using the order form in the back of every issue of Consumer Reports.
    Reel mowers
    These may be manual or engine powered. A spinning set of sharp spiral cutting blades working against a fixed 'bedknife' snips off grass like a scissors. In principle, reel mowers can produce an exceptionally consistent manicured lawn. However, small reel mowers may have serious cutting height limitations and also result in a wavy uneven appearance. See the Reel Mower FAQ for additional information on this type of beast.
    Rotary mowers
    These may be gasoline or electric (AC line or battery) powered. A spinning blade or blades whirls at the selected cutting height and lops off the tops of you grass by side impact. This is most definitely brutal treatment of your poor defenseless grass! The length of the cutting blade determines how much of a swath is cut on each pass - typically 18 to 24 inches for a walk-behind mower; up to 36 inches or more for a riding mower. Mowers with large swath widths may use two or more smaller blades instead.
    The uniformity, consistency, and just general appearance of a lawn mowed with a rotary lawn mower is not quite up to the standards of that of a professional reel mower. You will never get the perfect manicured look though some models may come close. However, the simplicity, lower cost, and need for less and more easily performed maintenance will generally overcome the desire for perfection unless your lawn is featured regularly in "Better Homes and Gardens" magazine.
    Gasoline powered rotary lawn mowers are by far the most common type used by homeowners and many professional landscapers as well. Most walk-behind mowers use a manual recoil (pull) starter though electric start is available on more sophisticated (and more expensive) models and generally standard on riding mowers and lawn tractors.
    The main disadvantages of a gasoline powered mower are the need to deal with the handling and storage of gasoline and routine engine maintenance at the end of the mowing season to assure easy starting next season and to prolong engine life. However, most of this is pretty straightforward. See the section: General preventive maintenance. Small gasoline engines also do contribute to air pollution but new mowers must meet more stringent EPA requirements as of September, 1996.
    Electric rotary mowers are also available in both plug-in and cordless (battery powered) versions. However, since gas mowers are generally more powerful and not limited by the length of a power cord or charge of a battery, they continue to dominate the market. Electric mowers are, of course, non-polluting but the electricity had to be generated somehow.
    Dead-man control
    All rotary mowers manufactured within the past 15 years or so must have a dead-man control to stop the blade quickly (within a couple of seconds) if the handle is released or the operator falls off of the seat of a riding mower or lawn tractor. While not foolproof, this feature greatly reduces the chances of serious injuries due to accidental slipping or falling - or attempting to make adjustments while the blade is spinning.
    WARNING: Never defeat the dead-man control for any reason unless there is no chance of the mower starting.
    Always restore the dead-man control to normal operation before attempting to start the mower.
    Types of rotary mowers
    In addition to options with respect to gasoline or electric power, rotary mowers can be classified based on such things as: walk-behind vs. ride-on, to bag or not to bag, and rear or side discharge or mulcher: WARNING: Most lawn mowing accidents result from reckless or careless use of riding mowers and lawn tractors, not walk-behind mowers. These are not as stable as an automobile especially when their large bags are full of heavy, wet, grass clippings and may tip over on inclines that would not be a problem with someone in control of a walk-behind lawn mower. They are best and safest for use on large flat open lots. A walk-behind mower - perhaps even a manual reel mower - should be used for sloping or irregular areas and for mowing or trimming around obstructions like trees, shrubbery, landscaping timbers, posts, fences, planters, boulders, and so forth.
    Putting a mower into service for the first time
    If this is a new purchase, you should have a users manual - READ IT!!!
    Above all, understand the very important SAFETY information.
    If there is some 'simple assembly required', take your time and follow the instructions step-by-step. Despite the apparent efforts of the designers of the mower and the manual writers to make everything as obscure as possible, it will probably go together without undo difficulty if you use the proper tools. With some, all you need to do is unfold the handle taking care not to pinch any control cables - oops - and you are ready to go to work. Happy times are here again!!
    IMPORTANT: For 4 stroke engines, make sure there is oil in the engine!!! Learn how to check it and fill it to the proper level if there is none or it is low. See the section: Checking the oil.
    WARNING: Running an engine without oil can ruin it in a few minutes and your warranty will not likely cover such stupidity. Since the lawn mower may be shipped without any oil, it is your responsibility to check this and then add the proper amount of the correct type of oil to the crankcase!!!
    For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) must be mixed with the gasoline in the correct proportions IN THE GAS CAN - not the fuel tank of the mower! See your users manual! Forgetting to use the proper mixture can ruin a 2 stroke engine in a matter of minutes and your warranty will not likely cover such stupidity. Adding the oil to the fuel tank is not recommended because thorough mixing cannot be assured.
    If you have yard equipment with both 2 stroke and 4 stroke engines, clearly label the two gas cans to indicate which equipment each is used in.
    Gasoline
    Use only fresh unleaded gas. Regular octane rating (87) is fine - small engines operate at relatively low compression ratios so knocking should not be a problem. There is likely no benefit to using anything higher. In fact, I've heard that small engines may actually be harder to start and run poorly on expensive high octane gas due to their low compression ratio. Gas that is over a month old may have lost some of its more volatile fractions resulting in hard starting, possible varnish formation, and other undesirable effects. At the end of the season, dump the unused (unmixed) gas into your car (preferably when its fuel tank is at least half full so your old gas gets mixed with fresh gas). This way you won't be tempted to use it at the start of the next season.
    For 4 stroke engines, gasoline is used as-is since there is a separate oil supply. For 2 stroke engines, you must mix the proper amount of the correct 2 stroke engine oil (outboard motor oil or whatever is recommended by your engine's manufacturer). Fill your '2 stroke mixture' gas can with about half the amount of gas you are preparing and add the proper amount of 2 stroke engine oil. Put on the top and slosh this around to thoroughly mix the oil in with the gas. Then add the remaining gas to the total amount for which your oil measurement was made.
    How do you tell if a lawn mower you just inherited has a 2 stroke or 4 stroke engine? The vast majority are 4 stroke - look for an 'oil filler cap'. On many, this is clearly marked with words like 'oil' or 'oil fill' or with a suitably ambiguous icon. Removing it will reveal a dipstick. (Note that unlike the engine in your automobile, this is both the test and filler location.) However, on more basic models, it may be near the base of the engine and be unmarked. In addition, there will generally be markings as to the need for the gas/oil mixture somewhere on the cover. The only major manufacturer of lawn mowers I know of that has used 2 stroke engines in recent designs extensively is Lawnboy.
    If you are unsure of the correct mixture ratio - they typically range from 16:1 to 32:1 gasoline:oil by volume - 16:1 is probably a safe choice. The worst that can happen is that the spark plug may be more likely to foul (and you will pollute more than necessary) but at least you won't risk damaging the internal parts from lack of oil. It is of course best to determine and use the recommended mixture ratio.
    Where to buy gasoline
    Your nearest auto service station will sell you small quantities of gasoline. As noted in the section: SAFETY, you must use an approved gasoline safety can which will be red in color. These come in sizes from 1 to 5 gallons or more and may be made of plastic or metal. A convenient size is 2 to 2-1/2 gallons. The fuel tank on a typical walk-behind mower will be between 1/4 and 1/2 gallon.
    WARNING: When filling your gas can, place it on the ground a few feet from your vehicle - never fill it inside the trunk or truck-bed. See the section: Where to fill gas can.
    However, a gallon of gas goes a long way with a walk-behind lawn mower. I don't have exact numbers but a gallon will probably do several acres of mowing (assuming you aren't chopping foot high grass!).
    If you must transport gasoline in a vehicle, make sure the container is secured in an upright position and tightly capped (both the filler spout and vent openings). Provide adequate ventilation so there can be no possibility of fume buildup in the trunk or passenger compartment.
    Always remove the gas can from vehicle before filling it. In addition to common sense 'what ifs' with respect to spills and fume buildup, there may be an added risk do the the buildup of static electricity:
    Also see the section: Explosion risk when filling a metal gas can.
    (From: Joyce (joduren@ix.netcom.com)
    Please be careful about filling the gas can. I saw something on one of those PBS How to do it shows (or was it in the newspaper?) that said that people are filling their plastic gas cans with them still in their trunks or hatchbacks. They said this is dangerous because the can isn't grounded or something and a static electricity spark could make the thing to explode.
    Gasoline additives or stabilizers?
    The use of a proper stabilizer can often substitute for the task of draining the gas between seasons by preventing the formation of insoluble gum that would otherwise eventually clog up your carburetor.
    "Isn't there a gasoline additive you can add to the gas which will keep it 'fresh' for up to 24 months? I've seen it at Home Depot, though have never used it. I think a tube was less than $1.00."
    (From: Floyd Reed (floyda@ix.netcom.com).)
    Being an old small engine mechanic from way back, I suggest that you don't use any additives to keep your gasoline 'fresh'. Dispose of old gasoline (end of season) by dumping it in the (nearly full) fuel tank of your car, then refill your gas can at the beginning of the mowing season. It should last you the season. With this method, you spend no extra on additives (that are no good for an engine), you don't waste 'old' gasoline, and you don't dump raw gasoline into the environment.
    (From: Dan Weise (dan_yz@cin.net).)
    I have found the commercial product Stabil the best thing since sliced bread. It prevents the gasoline in the gas tank from gumming up. I'm too busy to run around emptying gas tanks in the fall.
    Instead, I shoot in a squirt of Stabil, run the engine for 5 minutes, shut the gas valve off (unless it's a suction carb mounted on the gas tank) and the engines start next spring.
    That was *not* the case before Stabil. I can't count the number of times I've disassembled a carb and sprayed Gumout trying to unclog the main jet or the idle jet. Or had the float stick down and flood everything in sight. All because of gummy gasoline.
    I've used Stabil for about 10 years with great success.
    I also use that Slick 50 teflon stuff, but have no idea whether it does any good or not. But for the investment in an engine, I can't see that it hurts. The intermittent duty of many engines makes them more vulnerable to oil run-off than vehicles that are used daily.
    Before you start mowing
    Note: while written with gasoline powered rotary mowers in mind, most of these comments apply to electric models as well.
    Starting the mower
    Most mowers and other small pieces of gas powered yard equipment use a self retracting recoil type starter. You pull on a handle attached to a cord wound around a one-way clutch affair. Pulling on it rotates the engine's crankshaft and the clutch allows the engine to run without pulling you back into the mower! If yours has an electric starter, then you don't need to tug on anything - plug it in and push a button or turn a key. Of course, finding an outlet at the far end of a large yard may prove to be a challenge. With larger equipment like riding mowers, power is usually provided by an on-board rechargeable battery. In either case, there will be some kind of backup recoil or rope starter should the electric start be unusable or inconvenient.
    For the following, we will assume you pull a self-retracting starter rope. With an electric starter, replace the words: 'pull...times' with 'crank for several seconds'.
    Move the mower or other equipment to the place where it will be used - no sense in dragging a chugging lawn mower through the neighborhood. Position it on a solid level surface. Make sure there are no loose stones, twigs, branches, logs, etc. underneath to get sucked up and thrown about once you succeed in getting the engine started (if you ever do).
    When attempting to pull on the starter cord, it may be helpful to put one foot on the mower deck to brace it. Whether this is needed will depend on the design of your mower and in what direction the cord exits from the starter.
    You or the starter motor supplies the power to get it started. However, at the low speed of starting, special modifications may be required to the fuel system for the engine to catch. These may take one of the following forms:
    If the appropriate procedure is not successful, the engine may be flooded. You can give it 15 minutes or so for the gas to evaporate and try again or, if there is an IDLE or LOW speed position, open any choke and pull the rope several times in this position which should clear out the excess gas. Then repeat the recommended starting procedure.
    If none of this works, you may have a starting problem and should refer to the section: Lawn mower will not start. Probably, you forgot to fill the gas tank!
    A primer on priming
    Many small engines have replaced the choke with a primer - a rubber bulb or button that is supposed to be pushed several times before attempting to start the engine. Under the right conditions, this is a very effective approach. However, here are a couple of things to keep in mind:
    Where behavior seems to have changed, first confirm that environmental conditions are the same and the gasoline is fresh before blaming the engine on starting problems.
    Stopping the engine
    On most inexpensive lawn mowers manufactured within the last 10 or 15 years, releasing a dead-man bar on the handle both kills the engine and applies a brake to the blade (well, actually the flywheel of the engine). In this case, there is nothing to think about - just release the handle and it will stop within a second or two. These are quite reliable. The usual problem is that you forget to engage the dead-man bar and attempt to start the mower despite the basic fact that this is quite impossible!
    More expensive equipment will have a blade brake clutch meaning that while there is still a dead-man bar but instead of killing the engine when released, it disengages the blade (clutch) and brings it to a rapid stop (brake). This is more convenient especially with a balky engine. There will then be a separate engine stop switch - possibly combined with a speed/throttle control.
    Equipment with an electric starter may have an ignition switch just like an automobile and there will be three positions: STOP, RUN, START.
    Some older equipment just has a stop contact that grounds the spark plug. Pressing on a lever connects the spark plug terminal to the engine chassis and kills the spark. While this is fairly reliable, it may be a momentary contact meaning that the engine may be on a hair trigger and even rotating the blade a fraction of a turn may cause the engine to take off again. Thus, disconnecting the spark plug wire or removing the spark plug is even more critical when working on this sort of equipment.
    Suppose it fails to stop?
    What should you do if the engine stop switch has no effect? Probably the safest and surest is to use a wooden stick to pop the spark plug connector off of the spark plug terminal. This **will** stop the engine.
    The most likely cause of such misbehavior is a stop wire that has become disconnected or has broken. This is easily remedied.
    Maintenance Guide
    Here is what you should do at the end of the mowing season: Then, when it comes time to start mowing again (yes, I know, you can't wait), all you should have to do is add fresh gas (don't use last season's). The mower should start on the first (well, maybe, second) pull. There may be some white/blue smoke for a few seconds from it burning off the oil coating on the cylinder walls but this should quickly disappear.
    Here is another recommendation:
    (From: Bill Harnell (bharne@adss.on.ca).)
    Change the oil at the *end* of the season. No need to leave the acid charged oil in the crankcase over the winter to corrode the engine.
    Then add a couple of teaspoons or so of Stabilit to the gas tank. Run the engine for approximately 5 minutes and while you're at it, inject some fogging oil through the carburetor to thoroughly coat all of the interior surfaces. Directions are provided on the fogging oil container.
    Wipe the frame and handle with an oily cloth and oil all pivot points lightly. Clean the crud from under the deck - you do that frequently all summer - right? Remove all the grass clippings from around the flywheel and the cylinder fins.
    Then store it in the shed or garage.
    It will start on the first or second pull every spring.
    BTW, you should be able to get both Stabilit and fogging oil at any reputable engine service center.
    Checking the oil
    The following applies only to 4 stroke engines. For 2 stroke engines, special oil must be mixed in proper proportion with the gasoline.
    The proper amount of oil is critical to the happiness of your engine. Too little and it may overheat, cause excessive wear, and in extreme cases (but not unusual), cause engine parts to seize and fail - very expensive. Make it a habit to check the oil regularly. Doing this after about every 5 hours of operation is generally recommended. More frequent checks - such as before each time you mow - are fine as well. A typical small engine in reasonably good condition does not use up a lot of oil but checking oil is easy and will not hurt.
    Oil should be checked when the engine is cold or after waiting 10 minutes for it to drain back into the oil sump after running the engine.
    Place the mower on a level area.
  • If there is a dipstick - remove it, wipe it with a rag, and then reinsert it as directed on the information sticker or on the stick itself - usually threaded fully back in place and then removed to read. If the level is below or near the empty mark, slowly add the proper new oil to bring it up to just below the full mark.
  • If there is just a filler plug near the base of the engine, the correct level is just below the top - almost to overflowing. If lower than 1/4" or so below the lip, add new oil to top it off. (There may be exceptions to this but filling to near the top should be safe if you do not have your lawn mower engine manual handy.)
    If the oil level is high - you just bought the lawn mower or were careless in filling it last time - drain enough oil to bring the level back down to the full mark. Too much oil can result in problems as well - oil spraying out of various orifices or getting into other places where it should not be like the combustion chamber.
    If you find the oil level over the full mark or higher than it was before, gas may be leaking into the oil due to a flooded carburetor - a stuck inlet needle or bad float. If this is the case, the oil will need to be changed once the underlying cause of the leakage is determined. (This is only likely with float type carburetors such as those used on the Tecumseh engines used in a variety of Sears/Craftsman models equipment.
    If the oil is very low and you have been performing regular maintenance, there may be a leak or your engine may need a ring job. Excessive oil under the deck - on the shaft or blade adapter - would indicate a bad bearing or oil seal. Noticeable blue smoke while running would indicate that excessive oil is getting by the rings into the combustion chamber.
    Typical oil capacity is just over 1/2 quart (usually about 1-1/4 pints).
    About engine oil
    For the common 4 stroke engines such as Briggs & Stratton or Tecumseh, you don't need to buy specially high priced engine oil. The type likely used in your automobile will work fine and will be much less expensive. Although small engine manufacturers may recommend SAE 30 oil, they usually also state that 10W-30 or 10W-40 are acceptable substitutes - and these are what your car probably uses. New oil should have at least the SG rating though if you have some SF in your garage, that will be fine also (for your lawn mower, not your car!). However, there are situations like equipment that must run in extremely cold weather (probably not a problem with grass mowing!) where specific alternative oil recommendations should be followed.
    The capacity of a typical small engine is just over a 1/2 quart. This will probably cost you about 50 cents - a very worthwhile investment!
    However, some people do swear by synthetic oil. I remember it worked pretty well on my bicycle as well :-):
    (From: Daniel Pope (dpope@l-a-net.net).)
    Synthetic Motor Oil in the crankcase and Marvel oil in the gas is the only way to go!
    I have a $1,900 MTD tractor style mower with B&S engine (L head twin). It has over 800 hours and 9 years on it and I mean rough hours (bahaya grass and hot weather). The engine does not use a drop of oil (changed every 30 hours) and the compression is the same as when new. These other guys can have there $5,000 fancy mowers. I'll use that money to buy a truck.
    Oil change
    If you don't do anything else to prolong the life and happiness of your small engines (and your automobile, for that matter) it should be an oil change at the recommended interval. Oil loses its lubrication and cooling effectiveness with use and this will gradually take its toll on your precision engine parts. Even a simple lawn mower engine is machined to very precise tolerances and any contamination will increase wear. Ultimately, its performance - starting and running - will suffer and its life will be shortened.
    Since there is typically no oil filter, all the grit, metal particles, and other undesirable stuff continues to circulate with the oil to find its way in between precision engine parts.
    For small engines, the oil change interval is usually specified to be about 25 hours of use. More frequent oil changes may be desirable if the equipment is operated in an extremely dusty environment.
    A typical mowing season for a modest size lot is around this amount of time so an oil change once a season is probably satisfactory. I recommend this be done at the end of the season so that the old contaminated oil does not sit in the crankcase during the winter months and you will not (conveniently) forget to do this at the beginning of next season when you are eager to get at that straggly lawn.
    An oil change isn't really a big deal
    The oil change procedure is a lot simpler than for an automobile as everything is readily accessible and there is no oil filter to worry about.
    Blade sharpening
    The blade in a rotary lawn mower doesn't need to be sharp as a carving knife or scalpel but serious dents and nicks will result in a less than perfect lawn (to say the least!). In addition, a seriously unbalanced blade can result in excessive vibration and eventually, possible internal damage as well.
    First, drain the gas or remove the gas tank. If you will be filing steel, you get sparks. Sparks are not the greatest thing to have around gasoline vapor. Enough said. Disconnect the spark plug wire and tie it safely away from the spark plug or remove the spark plug entirely. Turn the mower on its side.
    CAUTION: Immediately check for oil leaks at the oil filler pipe or elsewhere. If there are any, you will need to work on the mower just propped up by 45 degrees or so. Or, use this as a good excuse to perform an oil change and drain the oil (even if the engine is cold, most of the oil will drain out but it will take a little longer). Just don't forget to refill the crankcase with fresh oil once you have completed work on the blade!
    Check that the blade isn't bent. Locate a reference point on one side and note the height of the blade tip at that location. Rotate the blade 180 degrees and check the height of the opposite blade tip. There should be no significant difference - say no more than 1/8" or so. If it is greater, the blade is bent or the crankshaft is bent. Either will require further investigation as running the mower under such conditions will probably result in excessive vibration and can be dangerous.
    Assuming this is fine, inspect the blade:
    Slight nicks and dents can be cleaned up with a file while the blade is still installed on the mower. Unless you have run into a curb, this is probably all that is needed on an occasional basis. Removing this small amount of metal will also not unbalance the blade enough to worry about. Refer to the section: Non-violent blade removal if it needs to come off the mower.
    If the damage is severe, consider replacing the blade entirely - they are not that expensive (usually under $10). Otherwise, you can use a file, a bench grinding wheel, or a grinding wheel mounted in an electric drill (there are special attachments for this specific application).
    Since the rotating blade also contributes to the proper air flow, you do not want to upset the shape. Grind in such a way that the original blade angle is preserved. It doesn't need (or want) to be razor sharp. A 1/64" edge is fine. Anything finer will quickly be dulled by little bits of stone and dirt in any case. Safety is not the main concern here - if any part of your anatomy contacts the whirling blade, you **will** be in trouble no matter how dull or sharp the blade might be!
    Attempt to remove approximately equal amounts of metal from both ends and in roughly similar areas if possible. If there are a few large nicks, it isn't necessary to remove them completely - your lawn (and neighbors) will never know the difference.
    Check the balance by positioning the blade at the center hole location on a pencil or other rod - you don't need a fancy blade balancer but can use one if you like. If it tips one way or the other, remove more material from the heavy side a little at a time.
    Replace the blade along with all its mounting hardware. Make sure you get all parts in the same relationship as they had originally. The blade must have its sharpened edges pointing downward. Don't forget the install the key if it is separate and DO NOT substitute a hard steel key for the soft metal one that should be used. See the section: Why soft metal keys must be used. If the locking key or blade adapter key appear damaged in any way, replace it.
    For just some minor touch up, there is no real need to remove the blade. For major grinding and balancing, removal will be needed. Removal will also be required to inspect for a damaged or sheared blade lock key and to replace it if necessary.
    In either case: disconnect the spark plug wire and tie it safely away from the spark plug terminal (several inches minimum) or remove the spark plug entirely to prevent accidental starting.
    If the nut holding the blade on is just on very tight, use a block of wood to prevent the blade from turning. Use a good quality socket wrench or box-end wrench of the correct size - an adjustable or even open-end wrench may not be enough. The nut usually unscrews counter-clockwise. However, check this out first! A careful inspection of the threads on the end of the crankshaft will reveal the direction. Or, determine the direction of rotation which will be designed to tighten, not loosen the blade. Most, if not all, single blade mowers rotate the blades clockwise as viewed from above which will therefore use a normal right-hand thread nut.
    CAUTION: Make sure that if the wrench slips, your flesh will not contact the blade or other sharp sheet metal - liberal use of rags or newspapers is a good idea. Arrange your position and the mower so you are pulling towards you - this is a more stable controllable arrangement.
    (From: Graduate student of school of hard knocks.)
    "I'd wish I'd read this a few years ago. I used an open-end wrench and it 'flexed' off of the bolt. Needless to say, my next week wasn't a lot of fun with 10 stitches in my hand."
    Use some penetrating oil (e.g., liquid wrench or WD40) on the nut and threads if there are signs of rust or corrosion. Allow it to soak in for a few minutes before attempting to remove the nut.
    You will prevail. A hammer or other more violent approaches should not be needed.
    Once the nut is loose, unscrew it the rest of the way by hand and remove any washers or mounting plate and note their exact position and orientation. The blade and adapter should come off easily. Some penetrating oil (e.g., WD40) may help if it is difficult to remove.
    If your adapter/blade doesn't pop off after removing the nut or bolt, it may be mounted using a taper like the flywheel. This is somewhat unusual on a walk-behind lawn mower but might be present on a larger machine like a lawn tractor. A wheel puller is best for dealing with this situation but first see if it isn't just gummed up or rusted in position - try the WD40.
    Inspect the key or locking tab for damage. You may have:
    If the adapter's tab is broken off or the key is sheared or damaged, then replacement of the entire blade adapter or just the key (depending on your mower's design) will be needed upon reassembly. For now, if you will be sharpening the blade, replace all the hardware in the correct positions (except the blade) and finger tighten the nut so you won't lose anything.
    WARNING: Do not install a hard steel key in place of the recommended blade lock key as you will lose the protection that the soft metal provides and the next incident may be the last... See the section:Why soft metal keys must be used.
    Once you have reground the blade or obtained a replacement, reassemble in reverse order and then tighten the nut to the proper torque.
    (From: Gib Gahan (gahan@esinet.net).)
    Another way to remove a stubborn blade is to take it to your friendly garage or tire changer and have them put an impact wrench on it. Saves knuckles, tempers, etc. Just don't put the blade back on without a touch of oil or anti-seize compound and of course, don't use an impact wrench!
    Carburetor adjustments
    If your engine is relatively new (made within the last 10 years or so) and has only one speed, then there may be no adjustments (like the one discussed in the section: Cleaning Craftsman (Tecumseh) carburetors. It will either work or it won't - in which case it needs cleaning or parts replaced. Or your overhaul was less than 100% effective. You can tell if your carburetor is of this type as there will be no adjusting screws on the carburetor. For Craftsman types, there will be a solid hex nut on the bottom holding the float bowl in place. There may or may not be a primer button.
    For adjustable types, it is best to refer to your engine manual. However, here is the general procedure. Some of the specific numbers may differ for your engine, however.
    In all cases, before touching any adjustments, make sure you air filter is in place, and clean (or new). Fill the fuel tank about half full with fresh gasoline.
    There are three adjustments on a typical carburetor:
    Initially, carefully and gently turn the two mixture controls in until they just seat.
    Note: "In" means clockwise (the way you would tighten a normal screw) and "out" means counterclockwise (the way you would loosen a normal screw).
    CAUTION: do not force them - you are not trying to tighten anything - as you will damage the needles and seats which will require replacement of the needles or entire carburetor. Then back them out 1 to 1-1/2 turns. Set the idle speed screw 1 to 2 turns beyond where it contacts the throttle plate. Refer to your engine manual for specific recommendations! These settings should allow the engine to start and run, though perhaps not entirely smoothly or with great enthusiasm.
    Notes on Briggs & Stratton tune-up
    (This assumes foam type air filter that needs have a film of engine oil in it to trap dust.)
    (From: (Willjim@gte.net).)
    Once the air filter is saturated it must be wrung out. I typically place them in a paper towel and squeeze. Then possibly a second paper towel. No oil should be dripping out of the filter when gently squeezed. Chilten's B&S engine section says to simply squeeze the filter of excess oil - no mention of a paper towel, etc.
    In adjusting the carburetor, Chilten says about 1-1/2 turns but 2 turns is my standard.
    I get the engine running first - warm it up to general operating temp. No applied choke, air cleaner installed. Adjust the main jet if you can get it to run at rated speed - preferably under load (turn in to the lean studder, out to the rich studder then back in about 1/2 way between these extremes). Then adjust the idle, at idle - at no load - using the same operation as the main jet. You may then go back and repeat/refine the process a second time as the idle adjustment may affect the main a bit.
    For the 92000 in particular (typical but refer to your specific engine model for exact specifications), from Chilten's second edition, "Repair & Tune-Up Guide for Small Engines" (successor to [2]):
    Setting engine speed
    Many inexpensive mowers don't even have a speed adjustment screw. Spring tension and the linkage to the governor set speed - period. Note that actual speed is rarely that critical for engine driven equipment as long as it is within safe limits. See the comments below on string trimmer speed settings. However, what options do you have where there is a need to set the precise engine speed?
    For equipment where a shaft with a known speed ratio to the engine crankshaft is available (i.e., a power take-off or trimmer head), an optical stroboscope of one form or another may be used. You will just need to paint or tape some stripes on the rotating part to put under strobe illumination:
    For example, for something like a string trimmer which has a direct coupled hub, strobe disks with 2, and 3, and 4 radial lines will appear stationary under fluorescent illumination for 3,600, 2,400, and 1,800 RPM respectively.
    There can be ambiguity but if you are already in the ball park, this sort of approach may be all you need.
    (From: Philippe Habib (phabib@netcom.com).)
    Go to a hobby shop that sells radio controlled airplanes. Plunk down $30 or so and get an optical tach. Paint 2 strips on the (crankshaft) hub of your equipment to simulate a propeller, and you're done.
    (From: J. Matthew Good (jmg14213@ix.netcom.com).)
    You shouldn't need a tachometer on a trimmer. Two stroke engines in the size and power range of line trimmers can't overspeed as they don't have the power with a line head installed. Just set the carburetor up so that it 'two-fours' at wide open throttle and you should be all set. If it needed to be adjusted with a tachometer, it would have some kind of governor on it.
    (From: Mowerman (mowerman2687@my-dejanews.com).)
    B&S engines have a spring in the governor arrangement. You want to change tension on the spring to change the speed. (This is basically true of most other small engines as well but the details will differ.) The spring is attached to a metal tung in the linkage at front of motor, this is made of a tinny metal so you can easy bend this tung. To lower speed you want to lessen the tension on the spring. You can do this while the motor is running at top speed but it would be safer to do the bending while mower is not running. By pushing in tung you will lessen top speed gently as it doesn't take much to alter that speed. Often this tung gets knocked in while mowing around bushes or other protruding material and "hey presto" your engine is only idling. It is a design problem that briggs should be working on, however I love B&S engines with their simplicity and ease of maintenance.
    Adjusting the carburetor on a 2 stroke engine
    This is generic advice but probably a good place to start. It assumes that there are 2 adjusting screws - idle and high speed mixture.
    (From: foxeye@www.compumise.com).
    I would start with them both backed out from the closed position to 2 turns open, for starters. One should be idle mix and the other should be high speed. Crank the motor, get it warmed up. You may have to fiddle with the throttle and or choke until its warmed up. Then slowly turn in the low speed jet, until it starts to die, then back it out another 1/4 to 1/2 turn. Then hold the throttle wide open, and slowly turn in the high speed, until it really starts to smooth out and rev high, and start screaming, then back this out until it starts to run rough or slow down, and then turn it back in to midway between these two positions. Keep playing with the low speed needle until you get rapid immediate response from the throttle, and good idle wit the idle adjustment. Then play with the high speed needle, but always back it out from the setting about 1/4 turn or so, from where it runs the smoothest. This setting of backing it out will allow more fuel when under a load, and keep your 2 cycle motor from running too lean. Put a load on it and just tweak the settings just a hair at a time. If your in the ball park it won't take much adjustment either way to make a difference. Better on the rich side than lean side. Also make sure your oil / gas is mixed at the proper ratio. 99% of 2 cycle motors are adjusted the same, no mater what brand they are. Most will start and run with both screws open 2 turns initially. Just don't close the high speed off any more than necessary no matter how well it runs.
    Troubleshooting Guide
    Instant troubleshooting chart - most common problems and possible causes
    The following chart lists a variety of common problems and nearly all possible causes. Diagnostic procedures will then be needed to determine which actually apply. The 'possible causes' are listed in *approximate* order of likelihood. Most of these problems are covered in more detail elsewhere in this document.
    While this chart lists many problems, it is does not cover everything that can go wrong. However, it can be a starting point for guiding your thinking in the proper direction. Even if not listed here, your particular problem may still be dealt with elsewhere in this document.
    (Portions of the following from: Chilten, Small Engine Repair 2-12 HP, (1).)
    This is probably the most common problem you are likely to encounter. The cause is very often the same - lack of maintenance.
    Note that the assumption here is that it cranks - the crankshaft and blade rotates in a normal manner but the engine never catches. Some larger (Briggs and Stratton) engines may have a low-oil cutoff switch which will stop the engine if the oil level is inadequate. However, this is not likely on a push mower.
    If you are unable to pull the cord (or the auxiliary starter on one with electric start), there may be a clump of grass stuck between the blade and the deck or there could be serious internal damage, especially if you just encountered an immovable object. See the section: Lawn mower will not start after the blade hit an obstruction. However, you didn't forget to engage the dead-man bar, did you? On most inexpensive mowers this safety interlock is needed to both enable the ignition system and release the blade brake.
    Determining why it won't start
    Think: FAST - Fuel, Air, Spark, Timing. Diagnosing a balky engine is not difficult but a step-by-step methodical procedure will make it a lot less traumatic. Despite all the warnings, serious problems rarely develop on their own. Most likely, there is a simple, easily remedied cause.
    Fuel
    Obviously, the engine won't run without gas!
    Once you have exhausted these obvious problems, determine if gas is reaching the cylinder as follows: Perform the normal starting sequence and then, assuming it shows no signs of wanting to start, immediately remove the spark plug. If fuel is reaching the cylinder, the spark plug should be damp with gas and there should be a very distinct odor of gas from the spark plug hole. If there is none, then there could still be a blockage in the fuel line or the carburetor may need cleaning.
    A flooded engine, most likely due to extended unsuccessful attempts at starting or a defective carburetor (float valve stuck open or gas-logged float) will result in inability to start as well and a distinct odor of gas. You might find raw gas coming our of various orifices - air filter as well as exhaust. (Note that in severe cases, enough gas gets mixed in with the oil to significantly increase the level in the crankcase and reduce the effectiveness of the oil. This will require an oil change.
    Air
    The optimal air:fuel ratio is around 14:1. This must be lower for a cold engine and thus a choke plate or other means to increase the richness of the mixture is usually provided. A choke plate restricts air intake forcing more gas to be sucked into the cylinder. A primer bulb effectively squirts gas into the intake pipe to augment the normal carburetor action. Some carburetors have no choke and no primer but incorporate an small gas reservoir which fills when the engine is off and provides some extra when starting.
    To much air results in a mixture that is too lean, burns too quickly, and can result in engine damage over extended periods of operation.
    Too little air results in a mixture that is too rich - there will be loss of power and possibly black smoke from the exhaust. This could be due to several factors:
    Spark
    All common lawn mower engines require a precisely timed spark to ignite the air-fuel mixture in the cylinder. The existence of a spark can easily be tested as follows:
    WARNING: make sure there is no gas in the vicinity when performing the following test!
    Remove the spark plug wire and insert the blade tip of an appropriately sized and well insulated (plastic) screwdriver inside the boot or clip in place of the spark plug. While holding the *insulated* part of the screwdriver, position the metal part of the blade about 1/8th inch from the block or frame.
    An alternative technique is to use an old, but good, spark plug whose gap has been increased to about 1/8 inch or one specially made for exactly this purpose. In this case, simply connect the spark plug wire to the test plug and hold its threaded part against the cylinder head or other part of the chassis (away from the gas tank!!).
    Note: Just positioning the spark plug wire a short distance from the spark plug terminal is not recommended as the results of this test will then depend on the condition of the spark plug as well since the spark will have to jump two gaps.
    Have a buddy crank the engine at normal starting speed so that you will be able to hold the screwdriver or test plug steady and be close enough to see any spark clearly. Shield the gap from the sun or bright light if necessary.
    You should see a nice healthy spark jump the gap several times on each pull (actually, once per rotation of the crankshaft/blade on both 2 and 4 stroke engines). Note: 4 stroke engines ignite the air-fuel mixture on every other rotation of the crankshaft. The extra sparks fire harmlessly into the exhaust gasses and are wasted. Can you believe it?!
    CAUTION: if you are not well enough insulated, *you* will jump several times per rotation of the crankshaft/blade if the ignition system is functioning properly! Hey, that *is* a valid test!
    If this test confirms the spark, it is still possible that the spark plug is fouled or bad. See the section: Checking the spark plug.
    If there is no spark, then there is a problem with your ignition system.
    Lack of spark
    If your mower is less than 15 years old, there is an excellent chance that if uses an electronic ignition system. These are very reliable as there are no points or condenser to go bad and no need for routine tune-ups.
    However, a number of other problems can result in lack of spark:
    Make sure stop switch/stop wire is in appropriate position - confirm with a multimeter, check that flywheel is being spun by starter and that flywheel key is intact to assure proper timing, check condition of points/condenser and setting (if applicable), test magnet (on flywheel) for strength, check the gap between flywheel and magneto core. If these are all fine, test or replace the magneto.
    In more detail:
    1. Check for a faulty or misadjusted STOP switch. This may be activated by releasing the dead-man bar or by a throttle control lever (STOP, RUN, START). Inspect the cable, linkage, and wiring for damage or for something that may have come loose. Make sure you have the controls set properly to run!
    2. Check that your starter is actually spinning the flywheel. If the flywheel is not rotating properly when you pull the cord or turn the electric start key, then there is a problem with the starter, not the ignition system. Or, the flywheel is not tight due to a sheared flywheel key or improperly torqued flywheel nut.
    3. Check for a flywheel that is loose and not seating properly on the taper. This could result in no spark if the air gap between the flywheel magnet and magneto core is then incorrect. However, due to the close spacing, you would probably feel and hear serious scraping in this case.
    Items (2) and (3) are likely if your just attempted to move a curb with your mower blade (or if someone inadequately tightened the flywheel nut during some previous maintenance).
    1. Check for bad connections or defective wiring including faulty or water logged insulation. If you just gave the mower a shower, wait ample time for it to dry out. High humidity may result in more problems if the insulation is not in good condition as well.
    2. Check for a weak (or missing) flywheel magnet. Both of these faults are extremely unlikely unless you have been hammering and whacking the crankshaft and flywheel in an effort to remove the flywheel. (This is not recommended - see the section: Flywheel removal.)
    3. (a) Electronic ignition - There is likely a single potted module which includes the circuitry and ignition coil. If anything goes wrong with this module, replacement is the only option. Once the wiring and resistance of the secondary has been checked, there are really no addition tests that can be performed on an electronic ignition module without special equipment. A defective ignition module will have to be replaced.
    1. (b) Breaker point ignition - Possibilities are bad, dirty, corroded, or loose points or points that are grossly out of adjustment, a bad condenser, or a bad magneto coil. See the section: Maintenance of point-type ignition systems.
    See the section: Testing the magneto.
    First, check that the dead-man bar is properly disengaging the stop switch when pulled and/or throttle control is properly disengaging the stop switch when in the start or run position.
    For anything beyond this, disassembly will be needed to identify and replace any defective parts.
    If the no-spark condition happened after after the blade hit an obstruction, (1) or (2) are likely. See the section: Lawn mower will not start after the blade hit an obstruction.
    Use the proper socket to remove the spark plug and inspect it for damage and general appearance:
    The best thing to do at this point is just replace it with a new spark plug and worry about the old one later. Actually, nearly every small engine maintenance book will recommend changing the spark plug every season anyhow.
    Testing the magneto
    The magneto, like the ignition coil on an automobile, contains two windings:
  • A primary with a few turns of heavy wire.
  • A high voltage secondary with thousands of turns of super fine wire.
    In an automobile, the battery supplies the primary current; in a magneto, the magnet on the flywheel moving past the core at high speed acts as a generator and induces current in the primary.
    As the magnets spin past the pole pieces of the magneto core, the points are closed and current builds up in the low voltage winding (and flux builds up in the core). At or slightly before Top Dead Center (TDC), the current (and flux) should be maximum and at this instant the points open. The flux then collapses (and the condensor (capacitor) across the points acts as a snubber allowing the current to bypass the open points and preventing arcing at the point contacts). This rapid decrease in flux results in coupling of the stored energy to the turn high voltage winding and results in up to 10,000 V or more at the spark plug.
    (For EE types, this is somewhat similar in basic operation to the flyback converter in a switchmode power supply except that the moving magnet supplies the input power instead of the rectified AC line and the points act as the switch instead of a power transistor.)
    The secondary will always be accessible for testing but the primary of an electronic ignition may be not be due to the electronic components:
    Wires can break due to corrosion or vibration. This would result in an open winding - infinite resistance. Shorts can develop between adjacent windings or to the core. This may be detectable as reduced resistance but without knowing exactly what it should be, there is no way of knowing if a slight discrepency represents a problem or just slight variations in design or manufacturing.
    A more complete test would involve checking the 'Q' or doing what is called a 'ring' test and even more for an electronic ignition. This requires special equipment. Therefore, it is best to swap in a known good unit. They are not that expensive.
    Timing
    For power to be developed, the ignition of the compressed air/fuel mixture must take place at exactly the correct instant - just before the piston reaches Top Dead Center (TDC) on the compression stroke. With automotive engines, there are mechanisms to advance the spark at higher revs but simple lawn mower engines do not have this complication, at least.
    Timing is set on older mowers with point type ignition systems by adjusting the point gap and generally only changes due to wear. However, these changes are gradual and unless the points come loose for some reason, will not likely suddenly prevent the mower from starting. On newer electronic ignition systems, there is basically no adjustment as the position of the electronic ignition coil/module fully determines ignition timing and this is fixed.
    However, timing can be grossly messed up if the flywheel key gets sheared and the flywheel then rotates a fraction of a turn on its mount on the crankshaft. The result may be a mower that does not start, backfires or runs erratically, lacks power, won't run and/or start when hot, etc. This is very likely to happen should the blade strike a rigid object causing the mower to stop instantly. In this case one or both of the blade lock key and flywheel key have sheared to (hopefully) protect the very expensive internal parts from damage.
    There are likely not going to be any timing marks for that old timing light you have sitting gathering dust somewhere. The only test really is to inspect the flywheel keyway to determine if damage has occurred.
    See the section: Lawn mower will not start after the blade hit an obstruction as this is the most likely cause of a sheared flywheel key.
    The following description applies to most small rotary lawn mowers with direct driven blades. The vast majority of these use either Tecumseh (as found a variety of Sears/Craftsman equipment) or Briggs & Stratton engines. However, similar comments apply to others as well including Lawnboy two stroke engines and the more modern Honda and other overhead valve type of engines.
    The assumption is that the engine started and ran normally prior to the incident. Now, no matter how many times you yank the starter rope or run the electric starter, it will not start at all, bucks, kicks back, backfires, or fails to develop enough power to keep going on its own.
    If the blade struck a solid boulder while the engine was set on 'high', more severe damage is possible as even with soft metal keys locking the blade and flywheel to the crankshaft, the inertia of the rotating blade is acting sideways against the crankshaft in addition to suddenly stopping its rotation. This can result in a bent crankshaft. The end of the crankshaft with the blade adapter could be bent without affecting the bearings or internal parts. This would need to be tested for as well. Not that such an occurrence is that much better - the crankshaft would still have to be replaced but at least the bearings in the crankcase will not be damaged.
    If the starter will not turn the crankshaft (assuming you remembered in your haste to engage the safety bar) - it is seized or will only rotate part of a revolution before hitting against something solid inside - then you probably have serious internal damage that will require a complete strip down and replacement of some (expensive) parts. If it turns but much more tightly than you recall (assuming you do have the safety bar engaged!) then the crankshaft may be bent - again very expensive. Repair may not be worth it.
    However, in most cases, what has happened is that either or both of the blade lock key and/or flywheel key have sheared to protect the crankshaft from serious (and terminal) damage.
    If the blade lock key broke, the blade will no longer turn rigidly with the crankshaft and provide the inertia required by many small engines with undersized flywheels. In this case, the engine may try to start but die out with a few "putt-putts" or even kick back on the starter cord. (As a side note, attempting to use a lawn mower engine as a replacement on a piece of equipment that doesn't have something to substitute for the blade's inertia may not work for this reason.)
    If the flywheel key broke, the ignition timing will likely be totally wrong and the result may be no ignition, backfiring, kickback, or weak or total loss of power.
    To diagnose, proceed as follows:
    First, pull off the spark plug wire and tie it securely away from the spark plug terminal (several inches minimum) or remove the spark plug entirely so that there is no chance of the engine accidentally starting. Even though it will not start now no matter what you do, the underlying problem could actually be a flooded carburetor or something else which may correct itself while you are working. Never take chances.
    Drain the gas or remove the fuel tank. This will prevent gasoline from spilling out the gas cap vent hole or flooding the engine through the carburetor since you will need to tip the mower to get underneath.
    Set the mower on its side (carburetor side up).
    The mower can usually be set on its side for a few minutes without harm but if these occur - you will have to work with it tipped less than 45 degrees or so - propped on wood blocks. Or, use this as a good excuse to perform an oil change and drain the oil (even if the engine is cold, most of the oil will drain out - it will just take a little longer). Just don't forget to refill the crankcase with fresh oil once you have completed your work!
    Using an old rag and/or proper work gloves, grasp the blade and attempt to rotate the blade and crankshaft.
    CAUTION, despite your lack of maintenance, the blade may be sharp!).
    The blade and crankshaft should rotate together. If there is slippage, the key has broken and will require replacement of just the key or the entire blade adapter plate depending on design. If it appears to be intact, then you can assume the flywheel key has broken. The blade key may be broken as well but it is not likely the reason for your failure to start. You should remove the blade to determine this for sure before restoring the mower to service in any case. See the section: Non-violent blade removal.
    You can possibly avoid removing the flywheel for inspection of the key by unscrewing the sparkplug, rotating the crankshaft so the piston is at TDC, and noting the location of the magnet on the flywheel relative to the magneto coil pole pieces. The magnet should be pretty close to the magneto in that position. If this is not the case or just to be sure, the flywheel will have to come off to inspect and possibly replace the key.
    To get at the flywheel key itself, some disassembly is required.
    Flywheel removal
    Remove the shroud (blower cover) if you have not done so already. This is usually fastened with 4 screws and hopefully does not involve any head bolts - if so, you will need to tighten them to the proper torque using a torque wrench once you have remedied the problem. You may need to remove the fuel tank (if you have not done this already) and other trim pieces as well.
    You should now see the top of the flywheel. In most cases, a large nut fastens the flywheel to the crankshaft. (However, in some designs, part of the starter mechanism is actually used and this is supposed to require a special wrench to remove. However, using a piece of wood as a buffer and tapping the ears in a counterclockwise direction will work also. Refer to your engine manual for details.) Use the proper socket to loosen this nut (counterclockwise). It may be necessary to brace the flywheel securely to gain enough leverage. Make sure this is done against something that can stand the force. Once loose, remove it by hand and then remove any washers or other parts that are under it. Make a note of how these were positioned including which side is up on some cupped washers.
    You should now see the keyway. The slots on the crankshaft and flywheel should be aligned. There are two common types of keys:
    You may even find that the flywheel is relatively loose on the crankshaft if rotating the blade while holding the flywheel stationary is possible. Either the blade key or the flywheel key or both are broken in this case.
    You will have to remove the flywheel to replace the key if it is broken or damaged.
    If the flywheel is loose at this point, then the following will not be needed as it can be lifted off.
    There are several approaches to flywheel removal:
    Flywheel removal on Briggs & Stratton engines
    The following applies to most B&S engines with the square starter shaft. This procedure will be needed to gain access to the points and condenser (on engines without electronic ignition), oil seal, etc.
    (From: Foxeye (foxeye@www.compumise.com).)
    The square shaft which turns one direction but not the other is the recoil starter pawl. This can be pulled straight up from the round cup that it sits in. There should be a couple of steel balls inside. Some models have a large internal snap ring that holds this in the cup. Remove ring, and pull it straight up. Use a magnet to remove the steel balls. Once you have this starter pawl removed, and the steel balls, hold the flywheel, stationary, and using a block of wood, bump one of the lugs on the outside of the starter cup in a CCW direction.
    Once you break it free of its torque, it should be able to be spun off CCW. Remove this starter cup, and the beveled bellville washer under it. Now your ready for your flywheel puller. A strap wrench can also be used to turn this starter cup loose. When installing the starter cup, make sure it is clean and free of grease and oils. A drop of oil or a light coating of grease on the crankshafts stub end (over which the starter pawl goes) is usually recommended. The starter cup only needs to be snugged down, and you don't have to go overboard trying to torque it to ungodly tightness. Snug is sufficient.
    Drop in the starter pawl, into the cup over the stub of the crank, and drop in the steel balls, replace larger flat cover over this assy, and insert snap ring if there was one.
    Flywheel inspection
    Once the flywheel is off, inspect the keyway on the crankshaft and flywheel for damage. Serious damage will require replacement of the affected parts. Slight burrs can be removed with a small file. If there are any cracks in the flywheel radiating from the hole, the flywheel MUST be replaced as this is a serious safety risk - the flywheel could literally explode when run at full speed. However, don't be concerned by surface flash - lines that look like fine cracks resulting from the molding process. To confirm that these are not cracks, there will be no visible penetration inside the shaft hole and fine sanding will quickly remove all traces of this flash.
    Assuming there is no serious damage, a new flywheel key should be all you need - about 25 or 30 cents. To confirm that this is all you need, replace the flywheel without the key but line up the two slots as they would be if a key were present. Tighten securely (but it doesn't need to be to the full torque as this is just a test). This should permit the mower to start and run normally but I would not recommend using the mower to actually cut grass until you replace the flywheel key.
    To install the new one, insert the key into the slot in the flywheel first and then slip the entire affair onto the crankshaft (I like to use a bit of WD40 for protection as well). The flywheel should seat securely with no detectable free play - it should be on straight and not rock back and forth at all. If this is not the case, the key may be in upside-down or there may be something or some particles of dirt or metal blocking it. Replace the washers, dirt screen, etc., and then hand thread the flywheel nut as far as it will go. Tighten to the specified torque (typically, 30-33 ft-lbs).
    Note: There may be a cupped washer between the nut/screen and flywheel. This must be installed cupped-side facing the flywheel or else you will be probably be replacing the flywheel key again very soon :-(.
    WARNING: Do not install a hard steel key in place of the recommended flywheel key as you will lose the protection that the soft metal provides and the next incident may be the last... See the section: Why soft metal keys must be used.
    Then, replace the shroud, fuel tank, etc. If head bolts had to be removed, it is probably a good idea to slightly loosen all of the head bolts and then retorque them to the proper value in the recommended sequence for your engine.
    Normally, the soft metal keys lock the blade and flywheel to the crankshaft. However, should the blade strike an obstacle and stop suddenly, one or both key(s) will shear and reduce the likelihood that the very expensive crankshaft or other parts will be damaged. The reason is that the substantial inertia of the crankshaft and that of the flywheel will tend to try to keep them rotating. Something has to give and you want it to be the 25 cent key and not the $75 crankshaft! However, this isn't foolproof as explained in the section: Why you really don't want to attempt to move an immovable object.
    Note that the soft metal flywheel key can also be damaged without totally shearing which may result in slightly incorrect timing. Symptoms may include a mower that is hard to start, runs rough or lacks power, or cannot be restarted when hot. Therefore, always replace the key if there are any signs of damage or wear.
    Engine dies or won't restart when hot
    (From: Wild Bill (kwag98@tcis.net).)
    There can be numerous reasons for the engine to quit running when it gets up to operating temperature.. expansion of metal parts where bolts/screws aren't tight enough, breakdown of the condenser for the ignition points (if equipped), or a possibility of a crack somewhere. An overall inspection of the tightness of fasteners would be a good place to start.
    (From: Walt Conner (jerrbear@midwest.net).)
    As soon as the engine shuts down, turn the flywheel by hand or DISCONNECT the plug wire and turn the blade by hand to see if there is any compression. I have had several B&S engines that did not have enough valve clearance and when hot, the valve stem expands in length enough that the valve does not properly close. After cooling, engine will be OK. Also could be a bad condenser or the other faults listed above.
    (From: Michael Stevenson (mike@gi4xsf.freeserve.co.uk).)
    Problems with the ignition coil can make an engine impossible to start when warm (or even stop running when it warms up), apparently this happens on motorbike engines quite often and is caused by a break in the HT coil.
    A carbon track forms inside the coil where the wire is b
