Notes on the Troubleshooting and Repair of Hand Held Remote Controls
Fifteen years ago, a wireless remote control was a $50 or $100 option (in 1980 dollars) to a TV or VCR. Early remote controls used ultrasound or radio frequency analog transmission and could perform only limited functions - you were lucky to get anything beyond on/off, volume, and channel up/down. Today, a remote control is standard with even the lowest cost basic electronic equipment. Nearly all modern remote controls use Infra Red (IR) light for digital data transmission. Some have more buttons and functions than a personal computer! Unfortunately, many have row upon row of tiny identical size buttons with no logical layout of functions. Others are a masterpiece of ergonomic engineering almost operating by themselves. There are two kinds of problems with remotes: 1. They seem to have legs of their own and disappear at the most inconvenient times. 2. They get abused by being dropped, dunked in Coke or beer, chewed on by the pet tiger, or left alone to develop dead leaky batteries. While there are some remotes that will respond to a whistle and beep back to identify their location, most are the ordinary deaf, dumb, and blind variety. I cannot help you locate your missing remotes. If you have disappearing remote syndrome, a well designed universal remote - on a tether - may make a good investment. However, the following was too good to pass up: (From: Bill Samuel (phantom@isoc.net)). "In '89, a Customer brings in their VCR for me to fix. (Zenith VRE-200) It won't accept tapes, plus their kids misplaced their remote, so they wanted a price on a new one. Well, after taking the unit apart, I called them and said, "Sir, I've found the problem with your VCR. BTW, you don't need a new remote."" Most actual problems with remotes can be solved relatively easily. They are often of a physical nature. Since remotes operate on low voltages under non-stressful conditions, spontaneous electronic failure is relatively uncommon. The following are not good for remotes: Sitting or stepping on them, using them as drink stirrers, door stops, projectiles for target practice, substitutes for dog bones, or depositories for your old leaky batteries.
Unless your remote hand unit has been run over by a bulldozer and is flat as a pancake, don't immediately assume it is actually broken. * First, confirm that your problem is not simply due to a selector switch in the wrong position or an accidental press of a key selecting 'VCR' instead of 'TV'. * If your 'problem' unit is a universal type, make sure it has not simply forgotten its programming or codes - reinitialize it. A common cause of memory loss is the batteries falling out or losing contact for an instant due to a fall or bump. See the section: "Forgot your universal remote setup?". * Some older TVs in particular may have a 'vacation' or other switch to disable the set (or just the remote functions). For that matter, if you cannot get the equipment to turn on at all, make sure it is plugged into a live wall socket :-). * Some TVs may occasionally become confused due to a power surge or for no good reason at all. Unplug the TV for a few minutes to reset it. * Before doing anything else, check and/or replace the batteries with fresh ones. Who knows how long they have been in there. * Don't ignore the possibility that your spouse (or the local poltergeist) accidentally dropped the remote spilling the batteries - and put some back in backwards! This could result in either a totally non-functional remote, weak (limited range), or erratic operation. Permanent damage is not that likely but possible with some designs if the resulting voltage to the circuit board actually had reverse polarity. * Next, try to determine whether the problem is indeed in the remote itself and not the TV, VCR, CD, or other controlled equipment. The easiest way to do this is to temporarily program a universal remote to match your equipment. If this now operates successfully, then you can be pretty certain that the problem lies in the remote unit. * If you are not able to get a universal remote to operate your equipment, then either you have not found the proper code setting or the remote itself is indeed faulty (or you don't have a universal remote!). * Should you or a friend have an identical or nearly identical piece of equipment, try the (faulty) remote on that (and its remote on your equipment) as a further test. * If you have multiple pieces of equipment, make sure you have not accidentally substituted an apparently identical remote for a slightly different model VCR, for example. Not all equipment - even of similar type - from the same manufacturer necessarily use the same signal transmission format.
To narrow down the problem, use an IR detector to determine if the remote is emitting an IR signal when each button is pressed. While this does not guarantee that the signal is correct, it eliminates most common problems from consideration. An IR detector card or an IR detector circuit like one of those described in the section: "IR detector circuits" are very handy for testing remote controls and other IR emitters. Some camcorders (those that do not incorporate an IR blocking filter) are sensitive to IR as well and will show a bright spot of light if aimed at a working source of IR. See the section: "Some alternative 'quick and dirty' remote testers" for additional options. MCM Electronics, Centerville, Ohio/1-800-543-4330, list 2 different shaped cards for $7.29 each (#72-005/3.5 x 2.5" card & 72-003 /4.75 x 0.75" probe. Radio Shack, Edmund Scientific, and others offer similar detectors. The salvaged IR sensor module from a TV or VCR may also be used as an IR detector. These usually operate from a single supply (12 V typical) and output a clean demodulated signal - you will not see the carrier, only the 1s and 0s. This will be true of an IR detector circuit as well unless you are careful to position the remote and photodiode just so as the circuit acts as somewhat of a low pass filter due to the B-E capacitance of the transistor. Radio Shack and Digikey (among other) also sell inexpensive IR receiver modules (under $5) which would also provide a demodulated signal for your viewing pleasure. However, note that some may be tuned for a particular carrier frequency like 40 KHz and therefore may not respond to all remotes. (Note, I have heard of spurious pickup issues with some of the Radio Shack units - they are not the same as those sold a while ago.) (From: Brett Walach (bwalach@dpg.devry.edu)). For anyone needing a great IR receiver at a reasonable price, try Radio Shack's MOD1. It's an IR receiver that demodulates the data for 40Khz x-mitters. The output can then be viewed on a scope or used to drive a small transistor which would in turn drive a speaker! The output from the MOD1 is the inverse of the code sent. That is, the TTL logic level from the MOD1 is high when no IR is present. If by chance you need an IR receiver that operates on a different carrier, try DigiKey (1-800-DIGI-KEY). I know that they have the other two types for sure.
Most problems occur in the hand units due to the abuse inflicted on them by
kids, pets, and even otherwise well behaved adults.  However, the equipment
or even outside interference can also be at fault.  Therefore, also see the
sections: "Problems with the equipment" and "Problems due to interference".
The following are the most common types of problems and suggested solutions.
As noted, most are physical in nature: dead batteries, gunk, bad connections.
For all but (1) and (2), disassembly will be required.  Manufacturers
seem to be using more and more creative (read: obscure and difficult to
open) methods of fastening the two halves of the remote shell together.
There may be a screw or two and/or the case may simply 'crack' in half by
gently prying with a knife or small screwdriver along the seam or sliding
the two halves a fraction of an inch to unlock some catches.  Look
for screws on the back (possibly under a not-so-easy to peel off label)
and inside the battery compartment, as well as hidden snap fasteners.
1.  Dead batteries or batteries inserted incorrectly:
    Solution obvious.  If batteries tend to go dead quickly - the batteries
    in a remote typically last years - then you may have a stuck button,
    some conductive grime under one of the buttons, or a defective IC - or
    you may be using cheap batteries.
    Make sure that all the batteries point in the correct direction as marked
    inside the battery compartment or under its cover.  If it uses more than
    2 batteries, getting one in backwards could also result in weak or erratic
    operation.
2.  Corroded battery contacts:
    Clean off the chemical deposits - first dust out the dried material with
    a soft brush and then remove the remainder with a damp lint free cloth
    or paper towel.  Polish the contacts with a fiberglass brush and/or pencil
    eraser and/or very fine sandpaper or a nail file.  If there is evidence
    that the battery juice made its way inside the case, you will need to open
    the remote and thoroughly clean the interior.  Additional repairs may be
    needed if damage to wiring, components, or circuit board traces is evident.
3.  Broken or intermittent contacts:
    There are most often between the battery connections and the circuit
    board.  Carefully resolder and reinforce them if necessary.  There
    could also be cracked solder joints on various component pins
    (particularly those that get abused like switches) as well.  Reflow
    the solder on any suspect joints.
    In addition, check selector, power, or enable) switches for proper
    operation.  Remove the batteries and use an ohmmeter to test across
    the contacts with the switch(es) in all positions.  These switches can
    be easily damaged as a result of dropping or squashing the remote.  The
    contacts may become dirty, gunked up, corrode, or simply wear out as
    well.  Locating a replacement may prove challenging.  Disassembling the
    switch may allow you to clean or restore the contacts in some cases.
4.  Broken Ceramic Resonator:
    These may fail from shock when remotes are dropped.
    The frequency is often 455 KHz (I assume since they are widely used as
    filters in the IF section of AM radios and are thus inexpensive.)
    If you have an oscilloscope, check for signals on the IC when buttons
    are pressed - if there is no action on any pin, then you may have a bad
    resonator (or bad IC, etc.).  Monitoring on one lead of the ceramic
    resonator should produce a signal at its resonant frequency when a button
    is pressed.  A typical waveform may have an amplitude of a few tenths of
    a volt.
    If you do not have a scope, one possible indication of a bad resonator
    (aside from it being smashed) would be a steady output from the IR LED
    for all button presses - normally the output would be visibly pulsating.
    Of course, this could indicate a bad IC as well.
    A ceramic resonator usually is a small blue or orange object that looks
    similar to a plastic (sharp edges) or dipped (smooth edges) capacitor.
    The circuit board marking will be X1 or CR1 or something like that.
    Replacements may be available from places like MCM Electronics or
    other electronics distributors.  Or, consider an organ donation from
    a remote for equipment that has long since gone to that entertainment
    center in the sky if the frequency of its resonator is the same.
5.  Dirt/spills/gunk/oily buildup inside:
    This may cause circuit problems preventing keys from operating reliably
    or physical problems resulting in keys being just plain stuck or sticky.
    If you have recently cleaned the outside with a wet or damp cloth (or
    in your dishwasher!), then this is quite likely as liquid can seep inside
    and result in all sorts of strange behavior immediately or delayed by
    some time.
    Disassemble completely and wash both sides of the rubber membrane
    keypad, circuit board, and plastic case with water (and mild detergent if
    necessary) to remove sugar based grime and then isopropyl alcohol - dry
    thoroughly.
    For stubborn crud, a pencil eraser and/or fiberglass brush may be used
    with care (on the circuit board only).  However, the gold plating (if
    present) and/or copper trace itself is quite thin!
    Where you find a oily film between the rubber and the circuit board,
    unless you really do a SUPER job of cleaning, it will come back quickly.
    Once you think you got it all, do it again - and with soap and water as
    well - both the rubber and circuit board.  Note: The consensus seems to
    be that the oils come from the human animal so it is just a consequence
    of the type of rubber (somewhat porous in spots) and usage patterns - not
    the result of dunking in a vat of motor oil (unless you did!).
    Caution: In some cases, the conductive black material may be soluble in
    alcohol - carefully test first on the pad of a key you don't care much
    about.  If black material comes off on your cloth or swab, use only the
    water and detergent.  Putting the black stuff back on is much more
    difficult than removing it :-).
6.  Worn or corroded pads on circuit board:
    These may be interdigitated or semi-circular patterns and suffer from
    both wear and corrosion.  Conductive Epoxy or other similar conductive
    paint (like that used for rear window defogger repair) or ink may be used
    for repair.  A piece of thin copper foil can be glued to the circuit board
    and soldered to the appropriate circuit trace.  (Gold foil would be better
    as it will not corrode but might be just a tad pricey for a $10 remote!)
7.  Worn conductive material on rubber buttons:
    Compare the bottoms of frequently used keys with those that are rarely
    pushed.  If you can see the rubber through the conductive material after
    cleaning, the pad is likely worn to the point of being non-functional.
    This may be repaired with conductive Epoxy or other similar conductive
    paint or ink.  A sliver of aluminum foil can sometimes be glued to the
    rubber surface. 3M makes EMI/RFI foil shielding tape, type 1181, that
    should work very well for this.
    MCM Electronics at 1-800-543-4330 lists a Rubber Keypad Repair Kit
    for $24.95.  It is supposed to contain enough material to repair 400
    contacts (2 containers each good for 200 contacts).  Their part number
    is 20-2070.  Not cheap but 400 contacts covers quite a few typical
    remotes.  Note: I do not know whether it is easy to mix only enough
    material for just 1 or 2 contacts - it would be worth confirming that
    this is possible before ordering.  Or else, invite a few dozen friends
    (and their flakey keypads) over for a remote repair party :-).
    There is also a material called 'resistive coating' or something like
    that that goes on like paint.  It may be available from an electronics
    distributor.  Or, if you are friendly with your local repair shop, they
    may be willing to spare a few drops.
    Occasionally, the conductive material is not actually worn off entirely
    only on the surface and there may still be some beneath surface.  Light
    sanding may help.
    (From: Paul Weber (webpa@aol.com)).
    "If you're looking for aluminum or copper foil tape with adhesive on it,
     visit your local hardware store, in the plumbing and/or roof rain gutter
     sections.  Alternatively, try an auto parts store.  I've found a variety
     of adhesive foils (including stainless steel) in these kinds of
     establishments.
     As for as repairing conductive rubber keypads:  I've not used the metal
     tape method, but will probably try it.  I've had great success with a
     thorough cleaning and light buffing of the contact area with very find
     (1000 grit) wet/dry sandpaper."
    (From: Rufus (Pink@Floyd.Edu)).
    "If you can find similar pads on another remote's membrane, trim them
     off square and use them to replace the defective pads.  You can use
     silicone glue to attach them.  Be careful to trim off the same amount
     from each pad so the buttons throw will be the same, and don't trim
     too deep as to damage the rubber dome."
    (From: Keith Craig (kcraig@mlode.com)).
    "I use a can of 'TV TUBE COAT' (GC Electronics), a conductive paint used
     for picture-tube aquadag (black paint on outside of picture tube used
     for ground).  Squirt a tiny amount on a piece of paper and use a Q-tip
     (cotton swab) to drop on the pad."
    (From: Mark Saterfield (kc4tzn@webtv.net)).
    "Pens are available that come preloaded with conductive ink at local
     electronics stores though apparently not Radio Shack."
    (From: Mike Harrison (wwl@netcomuk.co.uk)).
    "It isn't the same as the silver stuff used for car screen heaters, etc.,
     which I'd guess probably dries too hard and cracks off.  It's made by
     Circuit Works, who also do conductive epoxies.  Their part number is
     CW2610 for a repair kit, UK supplier is Farnell, price is UKP 22.33."
8.  Cracked circuit board:
    These can be repaired easily as the circuit boards are usually very
    simple, single sided, and have wide traces.  Use Epoxy or an adhesive
    like Duco Cement(tm) or windshield sealer to repair and reinforce the
    circuit board.  Scrape off any insulating coating and jumper breaks with
    fine wire and solder.  Do not just bridge the gaps with solder as cracks
    and future problems are a certainty.
9.  Bad IR LED:
    Test the IR LED(s) with an external power supply (with current limiting
    resistor) and IR detector and/or monitor voltage across them while
    operating.  Substitute a visible LED and see if it lights up when keys
    are pressed.  Use a scope to monitor the drive to the LED.  You should
    see the pulse code modulated carrier.  If faulty, replace with a readily
    available high intensity IR LED.
    Note that strictly speaking, these IR emitters should perhaps be called
    Infra Red Emitting Diodes or IREDs since they produce no visible light.
    However, we will use the term IR LED throughout this document since its
    meaning is understood by the vast majority of readers.
10. Bad IC:
    If the remote uses a custom chip, throw it away!  However, a failed chip
    is usually quite unlikely unless struck by lightening (now how would that
    happen?).  Even accidentally inserting the batteries backwards (though
    definitely not recommended!) - which tends to kill many devices - may not
    cause any harm to a remote.  Check each pin on the IC with a scope to
    determine if it is at least alive.
    (From: Duane P Mantick).
    "An awful lot of IR remotes use IC's from the same or similar series. A
     common series comes from NEC and is the uPD1986C which, incidentally is
     called out in the NTE replacements book as an NTE1758. A lot of these
     chips are cheap and not too difficult to find, and are made in
     easy-to-work-with 14 or 16 pin DIP packages. Unless you have no soldering
     or desoldering skills, replacement isn't difficult."
There are a large variety of preprogrammed universal remotes available starting at $10. These are set up by inputting a code number for each type of equipment you will be using - TV, VCR, Cable box, etc. Don't loose the instruction manual or you will not know what codes to use if the batteries go dead or the remote looses its memory for any reason! Record the codes in pen on a label on the back of the remote and inside the battery compartment. For general TV/VCR/cable use, the $10 variety are fine. However, many will not provide special functions like programming of a TV or VCR or access to other model specific menu functions. However, some of the One-For-All (and probably others as well) remotes do have capabilities not listed on the package (or web site). Check with the manufacturer (in the case of Universal, this can be via email) to determine whether any of their products have what is needed for your model(s). Universal 'learning' remotes are available at slightly higher cost (perhaps, $25-100). The better ones are capable of memorizing all of the actual signals sent by your original remotes by viewing the IR transmission directly. Of course, your existing remotes must be working properly for teaching purposes. Make sure you get a money back guarantee with these as some may not be compatible with all equipment. The advantage of a learning remote is that it can be taught to perform setup, adjustment, and programming functions as well as those for normal operation. However the teaching process is likely to be tedious and time consuming and you will have to keep track of which buttons do what - possibly not worth the effort in the end. If the backup batteries should ever go dead, the entire learning process will need to be repeated. (From: Michael Schuster (schuster@panix.com)). "You can get most of the Zenith OEM remotes from MCM Electronics. These include some that were sold under the Gemini name as consumer items; their 4-device learning/preprogrammed remote was particularly nice). These definitely =behave= as though they have EEPROMS; i.e. learned functions are retained indefinitely without power. Also the upgradeable one-for-all remotes from Universal Electronics (i.e. the ones with the 'magic' key) almost certainly have EEPROM since they can be customized by moving buttons around and assigning straight binary functions to keys not in the original pre programmed arrangement. Such customizations are also retained if power is lost."
In some cases, the only realistic option is to obtain an original replacement remote control. This might be the case where special functions need to be easily accessible or you have fallen in love with the button layout, style, or decorator colors! If you need to access special functions on your equipment, a learning remote might be an alternative if you have access to a working remote control so you can teach it. However, learning remotes are rarely as convenient as the original. As for color, there is always spray paint! * Consider the original manufacturer of the equipment only as a last resort as they will likely want to charge you an arm and a leg (or more) for a replacement. Panasonic has a web site you can enter your model number and get a parts list with list prices and part descriptions: * http://www.pasc.panasonic.com/ (Panasonic Parts & Service Online) This site includes support for Panasonic, Technics, and Quasar consumer electronics. However, my quick visit only showed accessory type items (e.g., replacement original remote controls, cables, etc.). Encrypted credit card protection presumably makes it possible to order parts directly. * Electronics distributors like MCM Electronics do stock a variety of original remotes - prices range from $9 - $143 (Wow $143 for just a stupid fairly basic remote! It doesn't even have high definition sound or anything exotic. You can buy an entire VCR these days for less than $143 including its own remote!), The average price of these replacements is a still rather inflated $40. * Remote and Manual Service offers factory original remote controls from a large number of companies. I do not know how their prices compare with the manufacturer direct or with places like MCM Electronics: - http://www.remotes.com/ (Phone: 800-REMOTES (800-736-6837))
While circuit problems with the hand unit discussed in the section: "Problems with remotes" are most likely, the following causes should not be overlooked if the remote does not work or has limited range: * Dirty IR window - The plastic sheet which covers the IR detector may be coated with dust, grease, grime, or tobacco smoke, or other wise damaged. If sensitivity has decreased even with a new set of batteries, this is a distinct possibility. It is not always obvious whether a particular type of dirt or damage will affect response. Some condensation may be totally opaque to IR while appearing transparent to visible light. On the other hand, I have a TV where someone must have cleaned the sensor window with sandpaper or a strong solvent - it is totally clouded over but works just fine with my $10 universal remote. Test by removing the front panel if possible and direct the remote at the sensor directly. Inspect and clean the sensor window thoroughly with mild detergent and water. * Defective IR sensor, receiver electronics, or microcontroller can result in the equipment simply ignoring you and/or doing whatever it pleases. The first two of these can generally be tested without service information. However, if they check out, advanced troubleshooting will be required. Borrow a replacement or universal remote to determine if the device responds with a known good unit. Check demodulated waveforms with an oscilloscope to confirm proper signal levels and reliable operation. See the section: "Diagnosing the problem" as well. Note that if this is a problem with new equipment (or if it has always been this way), don't neglect the obvious: Has the protective plastic film been removed? This is often present to prevent damage during manufacturing and shipping. It is amazing how many people neglect to remove this - I have gotten 10 year old TVs and VCRs at garage sales with this ugly film still in place! And, there could be a design or manufacturing problem with your set.... While the IR-receiver module inside that TV may be a mature component and may function well on the test bench, it is entirely possible that the TV manufacturer has made a (design) fault in applying it. An IR-receiver is a very sensitive device, and a television is a very dirty environment. This may be a case of an EMC problem, not an optical problem. Under the right conditions, with this type of IR-transmitters and IR-receivers, distances of 100 feet or better may be crossed... But, this should not be the customer's problem. The service organization of the TV manufacturer is the proper place to obtain a fix. The complaint is valid and it should be cured.
Symptoms for the following may range from no, intermittent, or incorrect response or greatly reduced range to the equipment being possessed - a TV changing channels, volume, or powering itself on and off as though being controlled by a poltergeist. These are likely possibilities if you have just changed your room layout or added something to it: * Interference from another remote in the same room which is defective (or is being squashed by a gorilla). Make sure there are no other IR transmitters including those like the a VCR+ or remote repeater that might be activated accidentally due to faulty programming or something pressing on the buttons. Do you know where all your remotes are hiding? A neighborhood kid (or adult with the maturity of a kid) may be playing tricks on you from outside your window or even across the street. It doesn't take much (a lens) to extend the effective distance over which a universal remote will operate reliably. Cover the sensor of the misbehaving equipment with a piece of black tape to see if the problem goes away. Then round up your other remotes (and/or other animate objects) and discipline them! * Fluorescent lamps using electronic ballasts - These may be newer ceiling fixtures or the energy efficient compact fluorescents used as replacements for the regular light bulbs in table lamps. The electronic ballasts are switching power supplies and these may result in modulation of the light intensity at high frequencies confusing the remote control receiver. Turn off all fluorescent lamps to see if the problem goes away. A cardboard baffle can be taped to the sensor to block the interfering light. Try a different brand of compact fluorescent as not all cause interference. * Bright lights in general - Enough ambient light, be it from the Sun or a 1000 W flood may overload the sensor. Ceiling fans can sometimes modulate the light with their fan blade rotation or vibration of the filaments of the bulbs which can confuse the remote control receiver and microprocessor. Turn off the lamps or move the Sunto see if the problem goes away. A cardboard baffle can be taped to the sensor to block the interfering light. Simply changing the orientation of a lamp shade or slightly moving one of components may be all that is needed. * Electrical interference from nearby equipment. Inadequate shielding in the sensor electronics could result in susceptibility to RF emissions from other gear. Turn off suspect devices. If the problem goes away, they will need to be moved to another location. Shielding is probably not a viable option.
Hopefully, you saved the instruction manual. No? Some universal remotes like the Zenith Allegro have an 'auto search function' which will sequence through all possible codes. You then push a button to lock in the proper settings when the TV or VCR's channel or power status changes. Of course, since you don't have the instruction manual, you likely don't know how to use this feature either! The manufacturer of the remote control is the next likely source (after the instruction manual) for the codes and other information. However, there is a good chance that one of the following web sites may be able to help you: * Memorex has a web site at: - http://www.memorex.com/core.html But they suggest using the technical support line (800-636-8352) for remote control programming and other Memorex consumer electronics questions. * Tandy (Radio Shack) has a nice web resource and fax-back service. This is mostly for their equipment but some of it applies to other brands as well and there are diagrams which may be useful for other manufacturers' VCRs, TVs, CD players, camcorders, remote controls, and other devices. - http://support.tandy.com/ (Tandy homepage) - http://support.tandy.com/video.htm (Link to video product info) In particular, - http://support.tandy.com/support_video/15787.htm (Link to remote info) lists many universal remotes including setup information. Since, it is likely that your model is actually one of these rebranded by Radio Shack, it is worth checking. * Universal Electronics, makers of the One-For-All(tm) line of universal remote controls (and other products) has a web site: - http://www.oneforall.com/ (Universal homepage) - http://www.oneforall.com/~universe/abcpro1.html (Remote controls) There is complete info on programming and special functions for many models. Since other universal remotes may be rebranded One-For-Alls, this information may be useful for those as well. * Zenith has an extensive web site with product specifications for many of their audio/video products. Gemini remotes (e.g., Easy-3) are made by Zenith. There is nothing there at the present time but indications are there may be remote information in the near future. - http://www.zenith.com/ Next time, make copies of the instruction manual(s) and put them in obvious places like taped to the back of the TV or inside the entertainment cabinet. Better yet, print the specific instructions and/or codes on a slip of paper and stuff it into the battery compartment of the remote. Or tape the info to the back and then cover with clear tape to protect it from wear. One of the primary axioms of life is that you will lose those instruction manuals :-).
Perhaps this is your lucky day and this is the type of remote you have that is in search of an instruction manual. I know this procedure works for models 3 and 4+ and assume it to be similar for the others. (From: Larry Sabo (sabo@storm.ca)). 1. Make sure the device you are programming is turned off. 2. Press and hold CODE SEARCH. 3. Press and release TV, VCR, or CABLE corresponding to the device to be controlled. The indicator light will flash once to indicate the search is enabled. 4. Release CODESEARCH. 5. Press OFF/ON repeatedly until the device turns on. 6. Press CHANNEL V (channel down) for verification. DO NOT press any other buttons at this time. If the channel changes on the device, the code is valid. Press ENTER to complete the search. If the channel does not change, turn off the device (without attempting to use the remote). Then continue search by repeating steps 5-6. When all codes have been searched, the indicator light will flash twice and the remote will return to the normal mode. (From: Aldrich TV, Inc. (aldrichtv@centuryinter.net)). I find it works better if you have the unit on and watch for it to go off. It is easy to miss it coming on and then you have already passed the proper code and have to start over.
Modern remotes use a pulse code modulated carrier to send the command.  Typical
carrier frequencies vary between roughly 36 and 56 KHz (although rumor has it
that Bang and Olefsun remotes may use 455 KHz for the actual IR carrier - I
have not been able to confirm this).  Each pulse or bit consists of multiple
cycles (e.g., 32) of this carrier.  Here are approximate measurements made of
the general characteristics of some typical remotes:
           Model           Carrier       Cycles/bit     Repeat rate
        Emerson VCR        36 KHz            32            10 Hz
        Mitsubishi VCR     38 KHz            10            20 Hz
        Panasonic VCR      56 KHz            48            10 Hz
        RCA TV             56 KHz            28            16 Hz
        Sony CD            40 KHz          24/48           20 Hz
        Sylvania TV        36 KHz            32            10 Hz
        Technics CD        56 KHz            48            10 Hz
        Toshiba VCR        38 KHz          20/320*          9 Hz
        Yamaha receiver    38 KHz          20/320*          9 Hz
For buttons that repeat, typical rates are 10 to 20 Hz and the entire code may
actually be sent only when the button is first pressed with only a 'repeat'
code sent while it is held down.  (* This extra length 'bit' was evident in
the repeat code for the Toshiba VCR and Yamaha receiver - which both seemed
to use very similar coding schemes.  Repeat for all keys used a 320 cycle bit
followed by an 80 cycle gap and a 20 cycle bit.)  It would appear that various
combinations of NRZ, RZ, PWM, and others are used depending on manufacturer
and model.  Think of the challenges involved in designing a universal remote!
The carrier frequency and coding schemes (these are even more varied than the
table above would indicate) have apparently not been standardized.  They may
also vary quite a bit even different models of equipment from the same
manufacturer.  Therefore, it is beyond the scope of this document to enumerate
them all.  It is possible to see these types of waveforms with an oscilloscope
by monitoring internal signals of the remote including certain pins on the
controller IC as well as the IR LED or its driver or across the transistor of
the IR detector circuit (see the section: "IR detector circuits").
The sites below have quite a bit of information on IR remote data transmission,
coding schemes, various circuits.  There are even tables of formats for the
remotes from a number of manufacturers:
        http://falcon.arts.cornell.edu/~dnegro/IR/
        http://www.hut.fi/~then/electronics/opto.html
        http://www.ee.washington.edu/eeca/text/
        http://www.ee.washington.edu/eeca/circuits/F_ASCII_Schem_IR.html
Here is an even more extensive list:
(From: Joe Krantz (joed.krantz@symbios.com)).
        http://www.circumspect.com/seits/Iremote.htm
        http://www.student.nada.kth.se/~d89-bga/hp48/index.html
        http://www.celadon.com/Consumer/consumer.html#TOP OF CONSUMER
        http://ourworld.compuserve.com/homepages/davidhuras/
        http://www.asihome.com/
        http://www.hometeam.com/hci/hcchack.htm
        http://www.homecontrols.com/hccremo.htm#remote
        http://www.derossi.com/hometech/brains/ucix.html
        http://www.student.nada.kth.se/~d89-bga/hp48/remote/index.html
        http://www.ee.washington.edu/eeca/text/ir_decode.txt
        http://www.ee.washington.edu/eeca/text/ircodes.txt
        http://www.irda.org/
        http://xenon.stanford.edu/~warren/remotes/index.html
        http://www.techmall.com/smarthome/4052.html
        http://falcon.arts.cornell.edu/~dnegro/IR/IR.html
        http://www.dbsdish.com/ofa_1.html
        http://206.214.38.196/~universe/ofa.html
        http://www.ee.washington.edu/eeca/circuits/PCIR/pcirhw.html
        http://www.dodgies.demon.co.uk/
        ftp://nada.kth.se/home/d89-bga/hp/remote/remotes/sony/sony.html
        http://www.tiac.net/users/wasser/OFA/SerialCable.html
        http://www.best.com/~ziggr/ir/
(From: Tomi Holger Engdahl (then@tinasolttu.cs.hut.fi)).
Almost all you can find free from the net you can find linked from
        http://www.hut.fi/Misc/Electronics/opto.html#irremote
Two approaches are shown below. * The first uses a bare photodiode as the sensor. It is simpler, lower power, and shouldn't care what, if any, modulation is used by the IR source. * An IR detector module salvaged from a TV or VCR, or purchased from Radio Shack or elsewhere may be used instead of a photodiode. This will have a much greater dynamic range (response to both weak and powerful signals) than a simple photodiode. However, some of these assume a particular modulation frequency and will be blind to anything else. Power requirements may also be more restrictive - it may insist on regulated 12 V).
This IR Detector may be used for testing of IR remote controls, CD player
laser diodes, and other low level near IR emitters.  It will not have the
sensitivity or dynamic range of the approach described in the section: "IR detector circuit using IR receiver module" but will respond to all sources
of IR falling within the wavelength range of the photodiode used since there
is not demodulation or coupling circuitry to get in the way.
IR radiation falling on the photodiode causes current to flow through R1
to the base of Q1 switching it and LED1 on.
Component values are not critical. Purchase photodiode sensitive to near
IR - 750-900 um or salvage from optocoupler or photosensor.  Dead computer
mice, not the furry kind, usually contain IR sensitive photodiodes. For
convenience, use a 9V battery for power.  Even a weak one will work fine.
Construct the circuit so that the LED does not illuminate the photodiode!
The detected signal may be monitored across the transistor with an
oscilloscope.
 Vcc (+9 V) o-------+---------+
                    /         /  R3
                    \ R1      \  500
                    / 3.3K    /
                    \       __|__
                    |       _\_/_  LED1 Visible LED
                  __|__       |
        IR ---->  _/_\_ PD1   +--------o Scope monitor point
          Sensor    |         |             (low active)
        Photodiode  |     B |/ C
                    +-------|    Q1 2N3904
                    |       |\ E
                    / R2      +--------o Gnd
                    \ 27K     |
       Gnd o--------+---------+
This one uses an entire IR receiver module as the IR sensor.  Its sensitivity
and dynamic range will be much better than the circuit described in the
section: "IR detector circuit using bare photodiode" since these modules
have automatic gain control circuitry built in.  However, some modules are
tuned to a particular modulation frequency and/or are AC coupled and will not
respond to all remotes or other pulsed or continuous IR sources.
The IR receiver module from a TV, VCR, or purchased from Radio Shack or
elsewhere, drives the base of Q1 through R1.  It may even be possible to
eliminate the transistor circuit entirely and connect the LED directly to the
module's output (in series with a current limiting resistor to Vcc or Gnd) but
that depends on the drive capabilities of the module.  You can use whatever
Vcc is required for the IR receiver module for the LED circuit as well but may
need to change the value of R2 to limit the current to the LED to less than
its maximum rating.
The specific case where Vcc is +5 V is shown.
                                 R2
    Vcc (+5) o------+-----------/\/\--------+
                    |           220       __|__
                    |+                      +--------o Scope monitor point
               +----------+                 |             (low active)
              -|    IR    |out    R1    B |/ C
       IR ---> : Receiver |------/\/\-----|    Q1 2N3904
              -|  Module  |      10K      |\ E
         Gnd o------+-----------------------+--------o Gnd
In addition to the IR detector circuits, IR detector card, and camcorder or video camera, here are a few other options: (From Malik (M.dad@mmu.ac.uk)). If you have a IR remote TV in the workshop for testing VCRs and other video equipment, you can modify this so that audio can heard from the speaker which represents the IR signal. Simply couple the output of the IR receiver (in the TV) to the input of the audio output stage. Use a low value ceramic cap and a high value resistor, this should be possible on all remote TV's and will cost you next to nothing. (What a nice idea! The only concern I would have is that not all IR transmitters use the same modulation frequency so I don't know how forgiving the demodulator in the IR receiver would be. Thus, you might think a remote control is bad when in fact it is just incompatible. You could probably learn to recognize the codes by ear after a while as well! :-) --- sam) (From: Paul Grohe (grohe@galaxy.nsc.com)). Here is a another "quick" and "very dirty" test of the IR emitter I have used: Clip a *glass* encased diode (1N34, 1N914, 1N4148, etc.) between your scope probe tip and ground clip. Crank the scope sensitivity up to about 20 tp 50mV/div. Hold the diode by the grounded lead (to reduce noise pickup). Point the "business" end of the remote directly at the clear part of the diode body. The IR packets will now be visible on the scope. You may have to move the remote around to find the "hot spot" in the window. The more of the diodes junction that is exposed, the better the response. A Sony remote generates about 50mVpp with a typical 1N4148/1N914 and more than 200mVpp with a "wide open" 1N34A point-contact Germanium (at 1 cm). BTW, the time constant of this setup may mask the actual 40KHz carrier pulses. Place a 100k resistor in parallel with the diode to see the individual pulses clearly (sensitivity *is* reduced). Or just simply hold the remote against an AM radio for a quick test. And, Filip also suggested that last one so I will honor him as well :-). However, the AM radio approach does not tsst the IR output but probably is an accurate test in most cases. --- sam. (From: Filip M Gieszczykiewicz (filipg@repairfaq.org)). Simply hold a pocket AM radio or Walkman set on AM and push the buttons. This works for all the remotes I have.... except the ultrasonic one :-). (From: Bob Quackenbush (quackenb@heidelberg-emh11.army.mil)). Tune an AM radio to a quiet area of the band, hold the remote near the (normally internal) antenna, press and hold any key on the remote. The sound will be a quiet fluttering, so listen carefully. Be careful with your interpretation of the results. "No flutter" may NOT mean that the transmitter isn't working. (From: David C. Brink (db@mcs.com)). Just dissect the remote far enough to get access to the IR LED(s) leads (if the remote has been through the moving bits of the Lazy-Boy a few times, such dissassembly might not even be necessary). Hold a LED in parallel with it and see if it lights when you press the remote buttons. (Note: since the voltage drop across an IR LED is usually less than that across a visible LED, this may not work unless the remote uses two LEDs in series. In that case, substitution may be needed. --- sam).
For operation between rooms, a repeater is best - an IR receiver that sends the data over a cable to an IR transmitter in the other location. This would require an IR receiver module similar to the one found in a TV or VCR, buffer to drive the cable, and a IR transmitter modulated at the appropriate carrier frequency (around 40 KHz typically). If extra distance or sensitivity is needed in the same room, it may not be too hard to replace the IR LEDs in the hand unit with more and/or higher power devices (though the IR LEDs used originally are generally quite powerful) but this would require some circuit hacking and possibly some reverse engineering of the design to determine what is possible. A small convex lens over the IR window on the receiver will help as well but will reduce the angle to the receiver over which response will be reliable. This would be suitable if you always use the equipment from a fixed location like a couch at the opposite end of the room. Where the transmitter and receiver are both in restricted locations, a short focal length convex collimating lens can be added to the transmitter as well as the receiver. The angular coverage of both receiver and transmitter will be reduced but the range will increase. Reducing the beam divergence by a factor of 2 at the transmitter will increase the range by approximately a factor of 2. Doing this at the receiver as well will add another factor of 2. Several hundred feet should be possible with very inexpensive lenses. I would suggest a lens of around 1 inch diameter with a 1 inch focal length. This is not critical but an IR detector circuit or card should be used to help set up the proper distance to the transmitter IR LED and receiver photodiode.
In some situations, it is desirable to be able to operate a remote controlled piece of equipment from another room - where a direct line-of-site path does not exist. One example of this would be to control a stereo receiver in the living room (which has speakers wired all over the house) from a bedroom. There are a number of ways of implementing this: 1. RF - An IR receiver in the bedroom retransmits the codes over on a radio frequency carrier to an IR transmitter in the living room. 2. Hard-wired - An IR receiver in the bedroom converts the IR to TTL (or other electrical) pulses wired to an IR transmitter in the living room. Where at least one video cable exists between the two rooms, a variation on this theme uses a combination of the coax shield and earth ground to send the signal between the rooms. 3. House wiring - An IR receiver in the bedroom modulates a carrier injected into the AC wiring. An IR transmitter picks off the signal from the AC wiring. In all cases, the IR receiver should be a module that includes automatic level control and generates a logic level output. If possible, it should NOT demodulate the IR signal so that the frequency of the carrier is maintained. The IR transmitter then only needs to convert this logic level to on-off IR pulses. Widgets based on all of these schemes are available commercially. (From: Robert Scott (Robert.Scott@ncl.ac.uk)). One of these circuits exists at: * ftp://ftp.ee.ualberta.ca/pub/cookbook/optic/irrepeater.tar.Z (From: Francis VE2FGS (sonytech@videotron.ca)). I personally have small pyramids called "Powermid" made by X-10 which work fine. Those come by pair, one transmitter and one receptor. You plug them in 120 VAC wall outlet and it transmit signals between the two pyramids with FM signals. It work very fine and I think it's the most practical, cheap, and fast way to transmit IR signals from one room to another. I paid about $40 (Canadian) for the pair.
(From: Donald Hoffman (dhoffman@epix.net)). I know of 2 links to such devices. Try: * The B.I.R.D. Computer Controllable Learning IR Remote: http://www.smarthome.com/8002.html * The RedRat Infrared remote control for your PC. http://www.dodgies.demon.co.uk/
