Pinouts for Various Common Chips and Hybrids
[Document Version: 2.07] [Last Updated: 05/25/1998]
1. About the Author & Copyright
2. Introduction
This document provides pinouts for some of the common integrated circuits
found in audio and video entertainment equipment like TVs, VCRs, and cassette
decks and computer monitors.  A good source for this information is the ECG
Semiconductor Master Replacement Guide (or the SK/NTE or other similar
databooks).
Note: the companion document: "VCR Power Supply Hybrid Regulators" contains
similar information for many of the common parts found in VCRs with linear
power supplies.
3. When to suspect the one of these chips?
The following are valid reasons for investigating the health of one of
these parts:
1. Scorch marks, discoloration, melted or bubbling plastic, device split in
   half, gobs of smoke, 6 foot flames.
2. Excessive heat.  While some of these chips or hybrids like power amplifiers
   will run hot, they should not be so hot that an egg would fry instantly.
3. Functional fault.  Since many of these parts have quite specific tasks to
   perform, the symptoms should provide some hint as to whether it is possible
   for the particular device to be at fault.  For example, your monitor no
   longer syncs properly would point to the sync separator.
4. Testing
First identify a suitable ground for your multimeter.  With the equipment
unplugged, test for continuity between the ground pin of the chip or hybrid
and the chassis or a metal shield.  Don't use the part's ground pin as
clipping anything to it increases the chance of an unfortunate short circuit.
First, check for power to the Vcc or Vss (or whatever) pins.  A large
percentage of failures will be due to lack of power or incorrect voltages.
The suspect device may or may not be at fault.  In many cases, a fusable
resistor has sacrificed itself possibly due to a short in the suspect
part or elsewhere (or opened for no good reason).
However, note that the 'typical Vcc' or other supply voltages listed in
this document or the device's datasheet may not be what your equipment
actually uses.  Therefore, a voltage that is moderately different than
the one listed for the device may be normal.
Once good power is confirmed, test the inputs and outputs.  Obviously, an
oscilloscope is generally needed for these.
Where multiple identical devices are present, substitution is usually an
acceptable troubleshooting technique but there is some risk involved as
faulty circuitry can blow your 'good' part.
5. Device pinouts
This list was compiled from replies to postings on sci.electronics.repair
and will be updated as new requests come in.  Contributions are welcome.
Please email in a format similar to those listed below.  If you provide
additional comments, your name and email address will be listed as well.
6. 6N138 - ECG3093
Optoisolater with split Darlington output.  Vcc = 18 V max., 8 pin DIP.
Pin 1: NC
Pin 2: LED Anode
Pin 3: LED Cathode
Pin 4: NC
Pin 5: Gnd/Q2 Emitter
Pin 6: Q2 Collector
Pin 7: Q1 Emitter/Q2 Base
Pin 8: Vcc/PD Anode/Q1 collector.
7. 93C66
Serial EEPROM.  512 x 8 or 256 x 16 bits.  8 pin DIP.
Pin 1: CS chip select, active high
Pin 2: CLK, serial clock, xfer on positive edge
Pin 3: DI, data in
Pin 4: DO, data out
Pin 5: Vss (ground)
Pin 6: ORG  (x8=vxx or x16=vcc)
Pin 7: NU (not used?) or TEST
Pin 8: Vcc 5 volts for C, other versions (LC) can runs +2 to +6v
8. AN5515 - ECG1684
TV vertical deflection.  Vcc = 24 V typ.  7 pin SIP-HS.
Pin 1: Ground
Pin 2: Output
Pin 3: Vcc for output
Pin 4: Input
Pin 5: Trigger pulse input
Pin 6: Pulse amp out
Pin 7: Vcc
9. AN6359 - NTE/ECG1812
VCR Servo Interface.  Vcc - 5 V.  20 pin DIP.
Pin 1:  Mode select B
Pin 2:  Gnd
Pin 3:  Mode select C
Pin 4:  Mode select X 1/2
Pin 5:  PAL/NTSC select
Pin 6:  B optput
Pin 7:  A output
Pin 8:  Error input
Pin 9:  Ref input
Pin 10: Amp input
Pin 11: Error output
Pin 12: Rec/Play select
Pin 13: Rec 2/4/6 H select
Pin 14: Mem
Pin 15: FG divide select
Pin 16: PB ctrl input
Pin 17: FG output
Pin 18: Vcc (5V)
Pin 19: FG input
Pin 20: Mode select A
10. BA336
Audio Level Sensor, used for a 'skip track' function, 9 pin SIP:
Pin 1: Pulse Width
Pin 2: Sense Timing
Pin 3: Input
Pin 4: NFB
Pin 5: GND
Pin 6: Muting
Pin 7: Noise Filter
Pin 8: Output
Pin 9: Vcc (Min: 4.2V, Max: 12V)
11. BA5115
Pin 1: PB level adj
Pin 2: PB output
Pin 3: LP (eq switch)
Pin 4: PB +input
Pin 5: Bias filter
Pin 6: Vcc
Pin 7: Rec output
Pin 8: Rec amp in
Pin 9: Rec/EE control
Pin 10: Mute control
Pin 11: Line output
Pin 12: Ground
Pin 13: ALC level
Pin 14: ALC off
Pin 15: ALC att/recv
Pin 16: Line amp in
Pin 17: PB/EE control
Pin 18: Line input
12. BA6209 - ECG1716
VCR Motor Driver with braking.  Vcc max = 18 V, I max = 1.2 A.
Pin 1: GND
Pin 2: Vout 1
Pin 3: Vz1
Pin 4: Vreg
Pin 5: Fin
Pin 6: Rin
Pin 7: Vcc1
Pin 8: Vcc2
Pin 9: Vz2
Pin 10: Vout 2
I would guess that you should be able to monitor Fin and Rin (forward
and reverse, I would assume) and determine if the commands are correct.
Vout 1 and 2 should probably be opposites of each other for forward (e.g.,
+,0) and reverse (e.g., 0,+).  They would be the same for stop.
I have no idea what the Vzs are or the Vreg.
13. BA6247
Pin 1: Ground
Pin 2: Motor drive
Pin 3: Motor drive
Pin 4: Logic
Pin 5: Logic
Pin 6: Logic
Pin 7: Vcc 12 V
Pin 8: Voltage divide
Pin 9: Voltage divide
Pin 10: Motor return
14. C4558C
Dual op-amp.
Pin 1: Out 1
Pin 2: -In 1
Pin 3: +In 1
Pin 4: -Vcc
Pin 5: +In 2
Pin 6: -In 2
Pin 7: Out 2
Pin 8: +Vcc
15. CNY75GB
Optoisolator, NPN phototransistor.
Isolation voltage, Vmax = 5300 V, gain = 100, Vcemax = 80 V.
Pin 1: LED K
Pin 2: LED A
Pin 4: Phototransistor E
Pin 5: Phototransistor C
Pin 6: Phototransistor B
16. DS8884
High voltage display driver for gas filled tubes.
Pin 1: Current Prog. In
Pin 2: A in
Pin 3: B in
Pin 4: C in
Pin 5: D in
Pin 6: D.pt.
Pin 7: comma in
Pin 8: comma out
Pin 9: GND
Pin 10: d.pt out
Pin 11: g out
Pin 12: f out
Pin 13: e out
Pin 14: d out
Pin 15: c out
Pin 16: b out
Pin 17: a out
Pin 18: Vcc
17. HA12002
Spike protector/voltage/temp/overload IC, (whatever that means!).
Pin 1: Relay driver
Pin 2: GND
Pin 3: Temp detect
Pin 4: Audio sig. in
Pin 5: AC detect
Pin 6: Overload detect
Pin 7: Bias
Pin 8: Pos feedback
18. KA2206/LA4183 - ECG1667
Dual AF PO, 2.3 W, 9 V (4.7 W bidge BTL).
Pin 1: BTL out
Pin 2: Out 2
Pin 3: Bootstrap 2
Pin 4,5: Pwr amp GND (tab)
Pin 6: Neg feedback 2
Pin 7: In 2
Pin 8: Decoupling
Pin 9: Preamp GND
Pin 10: In 1
Pin 11: Neg feedback 1
Pin 12,13: Pwr amp GND (tab)
Pin 14: Bootstrap 1
Pin 15: Out 1
Pin 16: Vcc
19. L200C - ECG1942
Positive adjustable voltage regulator.  Output: 3 to 36 V, 2 A.
Pin 1: Input
Pin 2: Limiting
Pin 3: Ground
Pin 4: Reference
Pin 5: Output
20. LA6324 - ECG987
Quad op-amp.
Pin 1: Out 1
Pin 2: -In 1
Pin 3: +In 1
Pin 4: +V
Pin 5: +In 2
Pin 6: -In 2
Pin 7: Out 2
Pin 8: Out 3
Pin 9: -In 3
Pin 10: +In 3
Pin 11: -V (or GND for some)
Pin 12: +In 4
Pin 13: -In 4
Pin 14: Out 4
21. LA7823 - ECG1647
TV Horiz/Vert Osc/Driver/Sync Sep/AFC.  Vcc 12 V typ, 16 pin DIP.
Pin 1: Flyback pulse in
Pin 2: AFC Out
Pin 3: Horiz Osc In
Pin 4: Horiz Osc Out
Pin 5: Holddown In
Pin 6: Gnd
Pin 7: Vert Drvr Out
Pin 8: Vert Drvr In
Pin 9: Vert Out Center Voltage
Pin 10: Vert Osc
Pin 11: Vert Osc
Pin 12: Sync Sep Out
Pin 13: Vcc - Vert
Pin 14: Video In
Pin 15: Blanking Out
Pin 16: Vcc - Horiz
22. LA7824 - NTE7123
Sync Deflection Circuit for color TV.  Vcc = 12 V typ.  16 pin DIP.
Pin 1: AFC Comparison Sawtooth Wave Input
Pin 2: AFC Output
Pin 3: Time Constant Circuit
Pin 4: Horizontal Output
Pin 5: Holddown Input
Pin 6: Gnd
Pin 7: Vertical Drive Output
Pin 8: Vertical Drive Sawtooth WaveInput
Pin 9: Vertical Output Middle Point Voltage
Pin 10: Time Constant Circuit
Pin 11: Vertical Trigger Output
Pin 12: Horizontal, Vertical Sync Sep Output
Pin 13: Vcc13 (Vertical)
Pin 14: Video Signal Input(Positive)
Pin 15: Composite Blanking Pulse Output
Pin 16: Vcc16 (Horizontal)
23. LA7831
TV Vertical Deflection, typical Vcc = 24 V.
Pin 1: NC
Pin 2: NC
Pin 3: GND
Pin 4: Vertical output
Pin 5: Vertical output stage Vcc
Pin 6: Input
Pin 7: Osc
Pin 8: 24 V Vcc
Pin 9: Pump up output
Pin 10 NC
24. LA7837 - ECG7104
TV vertical deflection, 13 pin SIP.
Pin 1: +Vcc1 = 12 V typical
Pin 2: Vert Trig In
Pin 3: Time constant
Pin 4: Vertical amp control
Pin 5: Vertical size control input
Pin 6: Ramp waveform generation
Pin 7: Vertical output FB
Pin 8: Vcc8 - 24 V typical
Pin 10: Osc stop
Pin 11: Gnd
Pin 12: Vertical Output
Pin 13: Power Supply for Vert Out
25. LA7838 - ECG7039
TV vertical deflection, Vcc1 = 12 V, Vcc8 = 24 V, 13 pin SIP.
Pin 1: +Vcc1
Pin 2: Vert trigger in
Pin 6: Ramp generator
Pin 7: Vert output AC/DC feedback
Pin 8: +Vcc8
Pin 9: Pump-up out
Pin 10: Osc stop
Pin 11: Ground
Pin 12: Vert output
Pin 13: Power supply for vertical out
The following is probably incorrect:
26. LA7837 - SK10085
Pin 1: +Vcc1
Pin 2: Vert Trig In
Pin 3: Vertical height control
Pin 4: 50/60 Hz Vert size control signal input
Pin 5: Ramp Waveform Generation
Pin 6: AC/DC Feedback Input to Vertical Output Section
Pin 7: Vcc7
Pin 8: Pump Up Output
Pin 9: Vertical Blocking
Pin 10: Gnd
Pin 11: Vertical Output
Pin 12: Power Supply for Vert Out
Pin 13: Ripple filter
27. LA7850 - ECG7086
TV/monitor deflection processor.
Pin 1: Horiz trig in
Pin 2: Phase adj time constant
Pin 3: Sync pulse time constant
Pin 4: FBP trig in
Pin 5: Sawtooth gen cap
Pin 6: Comp volt gen cap
Pin 7: Afc out
Pin 8: Horiz osc time constant
Pin 9: Discharge res
Pin 10: Vcc1
Pin 11: Horiz width set
Pin 12: Horz drive out
Pin 13: X-ray protect in
Pin 14: Ground
Pin 15: Vert drive out
Pin 16: sawtooth gen
Pin 17: Mid point volt control in
Pin 18: Vert osc time constant
Pin 19: Vert trig in
Pin 20: Vcc2
28. LM325
Dual Regulator, 14 pin dip.
Pin 1: +Boost
Pin 2: NC
Pin 3: +Vin
Pin 4: -Vin
Pin 5: -Current Limit
Pin 6: -Sense
Pin 7: -Vout
Pin 8: -Boost
Pin 9: NC
Pin 10: Reference
Pin 11: GND
Pin 12: NC
Pin 13: +Current Limit
Pin 14: +Sense
29. LM1881
Sync separator.
Pin 1: Composite Sync (out)
Pin 2: Composite Video (in)
Pin 3: VSync (out)
Pin 4: GND
Pin 5: Burst/Back Porch (out)
Pin 6: Reset
Pin 7: Odd/Even (hi/lo) (out)
Pin 8: Vcc
30. M51522A
Dual Audio Preamplifier by Mitsubishi Electronics.
Pin 1: Input 2
Pin 2: Feedback 2
Pin 3: Output 2
Pin 4: Ground
Pin 5: V+
Pin 6: Output 1
Pin 7: Feedback 1
Pin 8: Input 1
31. M54543L - ECG1628
VCR loading/bi-directional motor driver.
(From: Deon Maree (edm@pixie.co.za) I think the M54544L is the same as
the M54543L)
Pin 1: Vcc
Pin 2: Driver Vcc
Pin 3: Output 2
Pin 4: Input 1
Pin 5: Ground
Pin 6: Input 2
Pin 7: Output 1
Pin 8: Driver Vcc
Pin 9: Vcc
32. MC34166
Switching power regulator.
Pin 1: Voltage Feedback
Pin 2: Switch Output
Pin 3: Gnd - Heatsink
Pin 4: Pwr Input
Pin 5: Compensation
33. PA230, PA238 - ECG847
Low level audio amp, 12V Vcc, 8 pin package (14 pin DIP outline).
Pin 1: NC
Pin 3: Vcc
Pin 5: Compensation
Pin 7: Output
Pin 8: Gnd
Pin 10: Inverting input
Pin 12: Non inverting input
Pin 14: NC
34. STK0050
AF Power Amp, 50 W, Vcc = 36 V.
Pin 1: Input pos(+)
Pin 2: Vcc neg(-)
Pin 3: Output
Pin 4: NC
Pin 5: NC
Pin 6: NC
Pin 7: NC
Pin 8: Output
Pin 9: Vcc pos(+)
Pin 10: Input neg(-)
35. SAA7321
(From: Tony Duell (ard@p850ug1.demon.co.uk)).
Pin 1: CDR (Right channel Damping capacitor)
Pin 2: DER (Right channel De-emphasis network)
Pin 3: VRefR (Right channel reference)
Pin 4: VssAR (Right channel analogue ground)
Pin 5: VssA (Analogue ground)
Pin 6: VssAL
Pin 7: VRefL
Pin 8: DEL
Pin 9: CDL
Pin 10: INTL (Left channel Integrator output)
Pin 11: VddAL (Left channel +5V)
Pin 12: OALI- (Left channel Op-amp Inverting input)
Pin 13: OALI+ (Left channel Op-amp non-inverting input)
Pin 14: OALO (Left channel Op-amp output)
Pin 15: VddRef (+5V for reference)
Pin 16: VRO (Voltage reference output)
Pin 17: VRC (Voltage referece decoupling capacitor)
Pin 18: Test4
Pin 19: DAO (Serial data output (I2S) from the attenuator/clipper stage)
Pin 20: CLO (Serial bit clock output)
Pin 21: WSO (Word Select output)
Pin 22: Vdd1 (+5V)
Pin 23: Vdd2 (+5V)
Pin 24: Xtal2 (Crystal oscillator connections 11.2896MHz)
Pin 25: Xtal1
Pin 26: Xsys (System clock output from this oscillator)
Pin 27; Vss (ground)
Pin 28: Vss
Pin 29; Test1
Pin 30: WSI (I2S Word Select Input)
Pin 31: CLI (I2S Clock input)
Pin 32: DAI (I2S Data Input)
Pin 33: N/C
Pin 34: DEC (Demphasis control input)
Pin 35: Mute* (Active low mute input)
Pin 36: Att* (When low, attenuate outputs by 12dB)
Pin 37: Test2
Pin 38: tes3
Pin 39: VddA (Analogue +5V)
Pin 40: OARO
Pin 41: OARI+
Pin 42: OARI-
Pin 43: VddAR
Pin 44: INTR
Where signal names are uncommented, look for a similar name with L/R
swapped. It'll be the same signal in the other channel.
I2S input port is 16 bits, 44.1kHz. I2S output port is 4 times oversampled.
36. STK054 - ECG1028
20 W Audio Amp.
Pin 1 - -Vcc
Pin 2 - Out
Pin 3 - +Vcc
Pin 4 - Bootstrap
Pin 5 - NC
Pin 6 - NC
Pin 7 - FB
Pin 8 - In
Pin 9 - Gnd
Pin 10 - NC
37. STK457/STK459 - ECG1330
Dual AF PO, 15 W/channel, Vcc +/- 21 V typical. 16 pin SIP-M
See the section: "STK461/STK463 - ECG1331" for pinout.
38. STK461/STK463 - ECG1331
Dual AF PO, 25 W/channel, Vcc +/- 23 V typical. 16 pin SIP-M
Pin 1:  Chan 1 input
Pin 2:  Chan 1 feedback
Pin 3:  Gnd
Pin 4:  Chan 1 bias
Pin 5:  -Vcc
Pin 6:  Chan 1 feedback
Pin 7:  Chan 1 output
Pin 8:  +Vcc
Pin 9:  +Vcc
Pin 10: Chan 2 output
Pin 11: Chan 2 feedback
Pin 12: -Vcc
Pin 13: Chan 2 bias
Pin 14: Gnd
Pin 15: Chan 2 feedback
Pin 16: Chan 2 input
39. STK563F - ECG1732 - RCA #200750
TV +135 V regulator and 4 watt AF output combination in a 12 pin SIP-M case.
Pin 1:  Positive DC input
Pin 2:  Reg drive
Pin 3:  NC
Pin 4:  Negative DC input
Pin 5:  NC
Pin 6:  Reg voltage output
Pin 7:  Bootstrap
Pin 8:  Bias res
Pin 9:  AF output
Pin 10: Bypass
Pin 11: Gnd
Pin 12: AF input
40. STK0070 - ECG1322
See the section: "STK0080 - ECG1322".  Note: power and maximum Vcc may not
be the same as for the STK0080 or ECG1322.
41. STK0080 - ECG1322
AF PO, 80 W (ECG1322), Vcc = +/- 46 V typical.  10 pin SIP-M.
Pin 1:  Input +
Pin 2:  Vss -
Pin 3:  Output
Pin 4:  NC
Pin 5:  NC
Pin 6:  NC
Pin 7:  NC
Pin 8:  Output
Pin 9:  Vss +
Pin 10: Input -
42. STK0070II - ECG1335
See the section: "STK0080II - ECG1335".  Note: power and maximum Vcc may not
be the same as for the STK0080II or ECG1335.
43. STK0080II - ECG1335
AF PO, 80 W (ECG1335), Vcc = +/- 47 V typical, RL = 8 ohms.  10 pin SIP-M.
Pin 1:  Input +
Pin 2:  Vss -
Pin 3:  Output
Pin 4:  Filter cap
Pin 5:  Phase comp
Pin 6:  Phase comp
Pin 7:  Filter cap
Pin 8:  Output
Pin 9:  Vss +
Pin 10: Input -
44. STK4044V -- ECG1882
AF PO.  100 W, Vcc, +/-51V max.  15 pin SIPP.
Pin 1:  Input
Pin 2:  NFB (whatever that is)
Pin 3:  Substrate
Pin 4:  Bias
Pin 5:  Bypass
Pin 6:  Test Point
Pin 7:  I Adjust
Pin 8:  Compensation
Pin 9:  Emitter Bypass
Pin 10: I Adjust
Pin 11: Compensation
Pin 12: V(-)
Pin 13: Output
Pin 14: V(+)
Pin 15: Bootstrap
45. STK4101II - ECG1816
Audio Power Amp, 6 W, 8 ohms, Vcc = +/- 13.2 V, 18 pin SIP.
See the section: "STK4171V/STK4181V/STK4191V - ECG1317" for pinout.
46. STK4131
Dual AF PO, 20W/Ch, Dual Power Supply, Vcc=+/- 23V typ.  18-pin SIP.
Pin 1: Input 2
Pin 2: NFB2
Pin 3: GND 1
Pin 4: Feedback
Pin 5: I Bias 1
Pin 6: Muting
Pin 7: Mute Adjust
Pin 8: Mute T Cap
Pin 9: Power GND 1
Pin 10: Output 1
Pin 11: (+) Vcc
Pin 12: Bootstrap
Pin 13: Output 2
Pin 14: Power GND 2
Pin 15: I Bias 2
Pin 16: GND
Pin 17: NFB 2
Pin 18: Input 2.
47. STK4131II - ECG1817
Audio Power Amp, 20 W, 8 ohms, Vcc = +/- 22 V, 18 pin SIP.
48. STK4141II/STK4142II - ECG1818
Audio Power Amp, 25 W, 8 ohms, Vcc = +/- 26 V, 18 pin SIP.
49. STK4152II - ECG1819
Audio Power Amp, 30 W, 8 ohms, Vcc = +/- 27.5 V, 18 pin SIP.
50. STK4161II - ECG1315
Audio Power Amp, 35 W, 8 ohms, Vcc = +/- 30 V, 18 pin SIP.
51. STK4171II/STK4181II/STK4191II - ECG1316
Audio Power Amp, 50 W, 8 ohms, Vcc = +/- 35 V, 18 pin SIP.
52. STK4171V/STK4181V/STK4191V - ECG1317
Audio Power Amp, 50 W, 8 ohms, Vcc = +/- 35.5 V, 18 pin SIP.
Pin 1: Left channel input (-)
Pin 2: Left channel input (+)
Pin 3: Compensation
Pin 4: Compensation
Pin 5: Compensation
Pin 6: Muting
Pin 7: Compensation
Pin 8: Compensation
Pin 9: -Vcc
Pin 10: Left channel Output
Pin 11: +Vcc
Pin 12: Bypass
Pin 13: Right channel output
Pin 14: -Vcc
Pin 15: Compensation
Pin 16: Gnd
Pin 17: Right channel input (+)
Pin 18: Right channel input (-)
53. STK4162II
Dual AF PO, 50 W/Ch, dual power supply.  Vcc = +/-52.5V max.
Pin 1: Input 1
Pin 2: NFB 1
Pin 3: Gnd 1
Pin 4: Feedback
Pin 5: Input Bias 1
Pin 6: Mute
Pin 7: Mute Adjust
Pin 8: Mute T Cap
Pin 9: Power Gnd
Pin 10: Output 1
Pin 11: Vcc
Pin 12: Bootstrap
Pin 13: Output 2
Pin 14: Power Gnd 2
Pin 15: Input Bias 2
Pin 16: Gnd 2
Pin 17: NFB 2
Pin 18: Input 2.
54. STK5633 - ECG1742
130 volt regulator.
Pin 1: DC input (case)
Pin 2: Base
Pin 3: Common
Pin 4: Output
55. STK6982B - ECG1736
Four phase constant current step motor driver.  Vcc: 24 V, Il: 1.5 A typ.
18 pin SIP.
Pin 1: Vcc
Pin 2: Motor A common
Pin 3: Diode
Pin 4: Motor A
Pin 5: Input A
Pin 6: Motor A low
Pin 7: Low Input A
Pin 8: Re1
Pin 9: V ref
Pin 10: Ground
Pin 11: V ref
Pin 12: Re2
Pin 13: Motor B
Pin 14: Input B
Pin 15: Moto B low
Pin 16: Low B Input
Pin 17: Motor B common
Pin 18: Pause
56. STR11006 - ECG7092
Pin 1: V out/sense
Pin 2: Base drive
Pin 3: Input
Pin 4: Ground
Pin 5: Current detect
57. STR380 - ECG1548
Hybrid TV Voltage Regulator, 123 V, 1 A.
See the section: "STR381 - ECG1546" for pinout.
58. STR382 - ECG1553
Hybrid TV Voltage Regulator, 127 V, 1 A.
59. STR381 - ECG1546
Hybrid TV Voltage Regulator, 130 V, 1 A.  TO3 3 pin.
Pin 1: +DC Input
Pin 2: Output
Pin 3: Common
Pin 4: Base
Bottom view:
            Common
            3 o
        4 o       o 2
        Base    Output
Case is input - probably about 160 V.
Base is probably nearly the same as output.
60. STR30115 - ECG1896
Hybrid TV Voltage Regulator, 115 V, 1 A.  5 pin SIP.
See the section: "STR30135 - ECG1778" for pinout.
61. STR30120 - ECG1839
Hybrid TV Voltage Regulator, 120 V, 1 A.  5 pin SIP.
62. STR30123 - ECG1776
Hybrid TV Voltage Regulator, 123 V, 1 A.  5 pin SIP.
63. STR30125 - ECG1897
Hybrid TV Voltage Regulator, 125 V, 1 A.  5 pin SIP.
64. STR30130 - ECG1777
Hybrid TV Voltage Regulator, 130 V, 1 A.  5 pin SIP.
65. STR30135 - ECG1778
Hybrid TV Voltage Regulator, 135 V, 1 A.  5 pin SIP.
Pin 1: Common
Pin 2: Base
Pin 3: +DC Input
Pin 4: Output
Pin 5: NC
66. STR50041A - ECG1894
TV Voltage regulator, 41.8 V, 1.1 A.  5 lead formed SIP.
Pin 1: Vout sense
Pin 2: Base drive
Pin 3: Input
Pin 4: Common
Pin 5: Soft start
67. STR51041 - ECG1895
See the section: "STR54041 - ECG1796" for pinout.
68. STR53041 - ECG1840
TV Voltage regulator, 41.8 V.  5 lead formed SIP.
69. STR53043 - ECG1841
TV Voltage regulator, 43 V.  5 lead formed SIP.
70. STR54041 - ECG1796
TV Voltage regulator, 114.5 V.  5 lead formed SIP.
Pin 1: Vout sense
Pin 2: Base drive
Pin 3: Input
Pin 4: Common
Pin 5: Vout control
71. STR58041
Hybrid voltage regulator, output 115 V.
Pin 1: V out sense
Pin 2: Base drive
Pin 3: Input
Pin 4: Common
Pin 5: V out control
72. STR80145
(From: yonymar@aol.com).
The STR80145 is used in computer monitors. It is called a "Hybrid
Auto-Switch Module-Doubler". It allows monitors to operate at 110v or 220v
without having to use a selector switch. At 220v AC the IC allows the
bridge rectifier to function normally and pass the rectified AC to the
filter caps, at 110v AC the bridge rectifier voltage is sent to this IC to
be doubled to the equivalent of the 220v operation, automatically. The
rest of the circuit operates as if the input were 220v AC.
Pin 1: Delay
Pin 2: T1
Pin 3: T2
Pin 4: Gate
Pin 5: Common
73. TA7120
Audio Preamp.
Pin 1: Preamp Res
Pin 2: Input
Pin 3: Feedback
Pin 4: Gnd
Pin 5: Bypass
Pin 6: Output
Pin 7: Vcc
74. TA7136AP - ECG1464
Audio Preamplifier IC, Vcc = +/- 15v typical, Vg - 92 dB, 7 pin SIP.
Pin 1: Feedback
Pin 2: Input
Pin 3: Feedback
Pin 4: (-)Vcc
Pin 5: Bias
Pin 6: Output
Pin 7: (+)Vcc
75. TA7203 - ECG1154
AF Power Output, 2 Channel, 2 W/channel, 14 pin DIP-W, Vcc = 14 V typical:
Pin 1: Decoupling
Pin 2: Decoupling
Pin 3: Ch 2 in
Pin 4: Feedback Ch 2
Pin 5: Phase compensation
Pin 6: Phase compensation
Pin 7: Ch 2 out
Pin 8: Vcc
Pin 8: Ch 1 out
Pin 10: Phase compensation
Pin 11: Phase compensation
Pin 12: Feedback Ch 1
Pin 13: Ch 1 in
Pin 14: GND
76. TA7204 - ECG1153
AF Power Output, 4.2 W, 10 pin SIP HS, Vcc 12.5 V typical.
Pin 1: GND
Pin 2: AF out
Pin 3: Vcc
Pin 4: Bypass
Pin 5: Feedback
Pin 6: Feedback
Pin 7: Bypass
Pin 8: Feedback
Pin 8: Input bypass
Pin 10: AF input
77. TA7222AP - ECG1278
AF PO 5.8 W.  10 pin SIP-HS.
Pin 1: Vcc
Pin 2: Ripple reject
Pin 3: Muting control
Pin 4: AF signal input
Pin 5: FB filter
Pin 6: Gain adjust
Pin 7: GND
Pin 8: GND
Pin 9: AF output
Pin 10: Bootstrap
78. TA7267 - ECG7064
VCR loading/Bidirectional motor driver, 1 A. Vcc = 18 V (typical).
I would expect the normal output voltage to be close to whatever you have
for Vcc (just a guess).
Pin 1: In 1
Pin 2: In 2
Pin 3: Out 1
Pin 4: Ground
Pin 5: Out 2
Pin 6: Ve
Pin 7: Vcc
79. TA7291S
Bidirectional motor driver.
Pin 1: In 1
Pin 2: Vcc
Pin 3: Out 2
Pin 4: NC
Pin 5: GND
Pin 6: Vs
Pin 7: Out 1
Pin 8: Vref
Pin 9: In 1
Not sure if the second (or first) In1 is a typo - this is from ECG7043.
80. TA7313AP - ECG1465
AP PO, .5 W, 8 ohms, Vcc = 6 V (typical), 9 pin SIP.
Pin 1: Hi Freq Comp
Pin 2: Input
Pin 3: Feedback
Pin 4: Hi Freq Comp
Pin 5: GND
Pin 6: Out
Pin 7: Vcc
Pin 8: Bootstrap
Pin 9: Ripple Filter
81. TA7317P
Speaker protection IC:
Pin 1: Power on-off detection/Over current detection  (typical voltage -0.6V)
Pin 2: Direct voltage detection input (Typical voltage 0V)
Pin 3: Gnd
Pin 4: Gnd
Pin 5: Substrate (Typical voltage -0.8V)
Pin 6: Relay drive output/Typical voltage low 0.9v
Pin 7: Gnd
Pin 8: Muting circuit/Typical voltage 2.8v
Pin 9: Regulator input/Typical voltage 2.8v
This IC senses over current or a DC offset on the output to the speakers.
In the event of a offset it will operate a relay to remove any connection
between the amp and speakers so to prevent DC flowing through the speakers
and damage them.
82. TA7559P = ECG 778A
Dual op-amp.
Pin 1: Output one
Pin 2: Invert input 1
Pin 3: Noninvert input 1
Pin 4: V neg.
Pin 5: Noninvert input 2
Pin 6: Invert input 2
Pin 7: Output 2
Pin 8: V pos.
83. TA75902P
Quad op-amp.
Pin 1: Out 1
Pin 2: -In 1
Pin 3: +In 1
Pin 4: +Vcc
Pin 5: +In 2
Pin 6: -In 2
Pin 7: Out 2
Pin 8: Out 3
Pin 9: -In 3
Pin 10: +In 3
Pin 11: . (I assume -Vcc or Ground?)
Pin 12: +In 4
Pin 13: -In 4
Pin 14: Out 4
84. TA8201AK - ECG1832*
* May not be identical mechanical or electrical equivalent but should work
in majority of applications (!!).
12 W, AF PO.  Vcc = 13.2 V, RL = 4 ohms.  7 pin inline.
Pin 1: Input
Pin 2: NFB
Pin 3: Ripple rejection
Pin 4: Gnd
Pin 5: Out 2
Pin 6: Vcc
Pin 7: Out 1.
85. TAA611A12 - ECG1113
2.1 W Audio Amp, 15 V Vs max. Rl = 8 ohms. 14 pin DIP.
Pin 1: Bootstrap
Pin 2: NC
Pin 3: Frequency Compensation
Pin 4: Frequency Compensation
Pin 5: Feedback
Pin 6: NC
Pin 7: Input
Pin 8: Ground
Pin 9: NC
Pin 10: Ground
Pin 11: NC
Pin 12: Output
Pin 13: NC
Pin 14: Vs
86. TAA2761A
Dual op amp.
Pin 1:        +In A
Pin 2:        -In A
Pin 3:        V+
Pin 4:        -In B
Pin 5:        +In B
Pin 6:        Out B
Pin 7:        V-
Pin 8:         Out A
87. TC9174P
(From: Kim (103114.1526@compuserve.com)).
Interface IC for I/O Port Extension from Toshiba.
It is used for extension of output of digital tuning system controller LSIs,
TC9301AN/ 02AF/ 03AN.
Maximum Ratings (Ta=25 degree C)
Supply Voltage (Vdd) = -0.3 ~ 7.0 V
Input Voltage (Vin) = -0.3 ~ Vdd+0.3 V
Allowable Power Dissipation (Pd) = 600 mW
Output Voltage (Vout) = 20 V
Pin 1: GND                        Pin 16: Vdd
Pin 2: Output Port (OP)-1        Pin 15: Strobe Signal Input (STB)
Pin 3: OP-2                        Pin 14: Clock Signal Input (CK)
Pin 4: OP-3                        Pin 13: Serial Data Input (SI)
Pin 5: OP-4                        Pin 12: Serial Data Output (SO)
Pin 6: OP-5                        Pin 11: OP-10
Pin 7: OP-6                        Pin 10: OP-9
Pin 8: OP-7                        Pin 9:  OP-8
88. TDA1170 - ECG1289
TV Vertical deflection system IC.
Pin 1: Ramp Out
Pin 2: Vcc
Pin 3: Flyback
Tab 1: Gnd
Pin 4: Amp Out
Pin 5: Vs
Pin 6: Vreg Out
Pin 7: Height Adj
Pin 8: Sync in
Pin 9: Osc.
Tab 2:  Gnd
Pin 10: Amp Im
Pin 11: Comp
Pin 12: Ramp Gen
89. TDA1541A
Pin 1: Latch Enable(split mode)/Word Select(multiplexed modes)
Pin 2: Bit clock input
Pin 3: Data input (left chanel data in split mode)
Pin 4: Right channel data in split mode, otherwise not used.
Pin 5: Analogue Ground
Pin 6: Right channel audio output
Pin 7-13: Decoupling.  Connect to ground via separate 0.1 uF cap on each pin.
Pin 14: Digital ground
Pin 15: -15V supply
Pin 16,17: Oscillator capacitor (connect 470pF between these 2 pins)
Pin 18-24: Decoupling (7 more 0.1 uF capacitors)
Pin 25: Left channel audio output
Pin 26: -5V supply
Pin 27: Digital mode select input
Pin 28: +5V
Modes:
Pin 27 = -5V:  Separate channel data streams on pins 3 and 4. Pin 1 = latch
               enable
Pin 27 = 0V:  Time multiplexed offset binary data on pin 3. Pin 1 = word select
              (low = left, high = right)
Pin 27 = +5V: Time multiplexed 2's complement data on pin 3. Pin 1 = word
              select again.
90. TDA1670A/TDA1675 - ECG1862
TV vertical deflection output, 35 V max Vs, 15 pin SIP-HS.
Pin 1: Amp output
Pin 2: Amp supply
Pin 3: Osc
Pin 4: Osc
Pin 5: Sync in
Pin 6: Osc
Pin 7: Height adj
Pin 8: Gnd
Pin 9: Ramp generator
Pin 10: Ramp out
Pin 11: Amp in +
Pin 12: Amp in -
Pin 13: Blanking out
Pin 14: Vs
Pin 15: Flyback
91. TDA1770A
Pin 1: Blank ouput
Pin 2: +supply
Pin 3: Flyback
Pin 4: NC
Pin 5: Ground
Pin 6: Ground
Pin 7: Ampl out
Pin 8: Ampl supply
Pin 9: Osc
Pin 10: Osc
Pin 11: Sync input
Pin 12: Osc
Pin 13: NC
Pin 14: Height adj
Pin 15: Ground
Pin 16: Ground
Pin 17: Ramp generator
Pin 18: Ramp out
Pin 19: Ampl in+
Pin 20: Ampl in-
92. LA7851 - ECG 7062
Vertical Deflection Circuit/Sync/H V Osc/X-ray Prot.  Vcc = 12 V.  20 pin DIP.
Pin 1: Horiz drive pulse width setting
Pin 2: Horiz drive output
Pin 3: Xray protect input
Pin 4: Gnd
Pin 5: Vertical drive output
Pin 6: Vertical Sawtooth wave generator
Pin 7: Middle point Voltage control input
Pin 8: Vertical oscillator  T C
Pin 9: Vertical trigger output
Pin 10: Vertical  VCC
Pin 11: Horizontal trigger input
Pin 12: Phase adjust T C
Pin 13: Sync Pulse Width TC
Pin 14: FBP trigger input
Pin 15: Sawtooth wave generating capacitor
Pin 16: Comparison voltage generating capacitor
Pin 17: AFC output
Pin 18: Horizontal OSC TC
Pin 19: Discharge resistor
Pin 20: Horizontal VCC
93. TDA1905 - ECG7000
AF PO, 5W, Vcc = 14 V, Rl = 4 ohms.
Pin 1: Out
Pin 2: Vcc
Pin 3: Bootstrap
Pin 4: Threshold
Pin 5: Muting
Pin 6: Invert In
Pin 7: Svr
Pin 8: Non-Inverting In
Pin 9-16: Ground
94. TDA2003 - ECG1288
10 W AF Power Amp.  TO220 5 Pin.
Pin 1: + In
Pin 2: - In
Pin 3: Gnd
Pin 4: Out
Pin 5: V+
95. TDA2005 - ECG1396
20 Watt bridge amp for car radio, manufactured by SGS-Thomson.
Pin 1:  Input 1 (+)
Pin 2:  Input 1 (-)
Pin 3:  Svrr
Pin 4:  Input 2 (-)
Pin 5:  Input 2 (+)
Pin 6:  Ground
Pin 7:  Bootstrap 2
Pin 8:  Output 2
Pin 9:  +Vs
Pin 10: Output 1
Pin 11: Bootstrap 1
96. TDA2040 - ECG1376
AF PO 22 W, Vcc = 32 V, Rl = 4 ohms.
Pin 1: -In
Pin 2: +In
Pin 3: -Vs
Pin 4: Out
Pin 5: +Vs
Pin 3 connected to case.
97. TDA2577 - ECG1632
Horizontal, Vertical Oscillator, Sync, Driver. Vcc1 = 12 V typical.
Pin 1: Vertical Drive Out
Pin 2: Vertical Feedback
Pin 3: Vertical Frrequency Adj
Pin 4: Vertical Sync Sep
Pin 5: Video Input
Pin 6: Horizontal Sync Sep
Pin 7: Horizontal Sync Sep
Pin 8: Slow Phse Det
Pin 9: Ground
Pin 10: Vcc
Pin 11: Horizontal Drive Out
Pin 12: Horizontal Flyback Input
Pin 13: Mute Out
Pin 14: Phase Det.
Pin 15: Horizontal Frequency Adjust
Pin 16: Start Circuit Stab
Pin 17: Sandcastle Out
Pin 18: Coincidence Det
Aside from those that have obvious meanings, I do not know what the
other signals do.
98. TDA2578A
Synchronisation circuit with vertical oscillator and driver stages.
Pin 1: Vertical Drive output
Pin 2: Veritcal feedback (e.g. from sense components, bottom of yoke circuit)
Pin 3: Vertical oscillator timing components
Pin 4: Vertical sync separator R/C network
Pin 5: Video input
Pin 6: Horizontal sync separator input
Pin 7: Sync slicer output (connnect to 6 via RC network)
Pin 8: Slow (horizontal) phase detector RC timing components
Pin 9: Ground
Pin 10: +12V
Pin 11: Horizontal Drive output
Pin 12: Horizontal flyback pulse input
Pin 13: Mute and 50/60Hz indentification
Pin 14: Phase detector 2 timing capacitor
Pin 15: Horizontal oscillator timing components
Pin 16: Startup current input
Pin 17: Sandcastle pulse output
Pin 18: Coincidence detector timing capacitor
99. TDA3505
Chroma Control Circuit.
Pin 1:  Red Signal Out
Pin 2:  Storage Cap Cutoff Green
Pin 3:  Green Signal Out
Pin 4:  Storage Cap Cutoff Blue
Pin 5:  Blue Signal Out
Pin 6:  Vcc
Pin 7:  Storage Cap Blue
Pin 8:  Storage Cap Green
Pin 9:  Storage Cap Red
Pin 10: Sandcastle Pules In
Pin 11: Signal Switch In
Pin 12: B Signal In
Pin 13: G Signal In
Pin 14: R Signal In
Pin 15: Y Signal In
Pin 16: Sat Control Voltage
Pin 17: R-Y In
Pin 18: B-Y In
Pin 19: Contrast Control Voltage In
Pin 20: Brightness Control Voltage In
Pin 21: White Point Adjust Blue
Pin 22: White Point Adjust Green
Pin 23: White Point Adjust Red
Pin 24: GND
Pin 25: Beam Current Control In
Pin 26: Auto Cutoff Control In
Pin 27: Storage Cap Leakage Current
Pin 28: Storage Cap Cutoff Red
100. TDA4440
Video-If-Amplifier for color and monochrome television receiver.
Manufactured by Telefunken electronics.  Vs = 10 to 15 V.
Pin 1: Input
Pin 2: NC
Pin 3: Gnd
Pin 4: Decoupling (connect to an electrolitic capacitor).
Pin 5: To Tuner
Pin 6: Tuner control
Pin 7: Gating pulse
Pin 8,9: 38.9 MHz tank
Pin 10: NC
Pin 11: Negative video output
Pin 12: Positive Video output
Pin 13: Vs
Pin 14: NC
Pin 15: Gnd
Pin 16: Input
101. TDA4555
Multistandard Color Convertor.
Pin 1:  (R-Y) Out
Pin 2:  SECAM (R-Y) De-emph
Pin 3:  (B-Y) Out
Pin 4:  SECAM (B-Y) Ref In
Pin 5:  SECAM (B-Y) Ref Out
Pin 6:  SECAM (B-Y) De-emph
Pin 7:  SECAM (R-Y) Ref Out
Pin 8:  SECAM (R-Y) Ref In
Pin 9:  GND
Pin 10: Delay Chroma Signal In
Pin 11: DC Ref Delay Line
Pin 12: Out Chroma S/D Line
Pin 13: Vcc
Pin 14: Work PT Con Chroma Amp
Pin 15: Chroma Signal In
Pin 16: ACC
Pin 17: Hue Control/Service Switch
Pin 18: Phase Control Osc
Pin 19: Crystal for Osc
Pin 20: NTSC ID
Pin 21: PAL/SECAM ID
Pin 22: SECAM ID Ref
Pin 23: SECAM ID Sel
Pin 24: Sandcastle In
Pin 25: Switch Voltage In/Out NTSC 4.4
Pin 26: Switch Voltage In/Out NTSC 3.5
Pin 27: Switch Voltage In/Out SECAM
Pin 28: Switch Voltage In/Out PAL
102. TDA4605
SMPS controller.
Pin 1: Regulation input
Pin 2: Primary current simulation
Pin 3: Primary voltage monitoring
Pin 4: Gnd
Pin 5: Output
Pin 6: Supply voltage
Pin 7: Soft-start
Pin 8: Zero crossing detector
103. TDA8340
(From: Alex Suhisky (a1ex@q-net.net)
  and  Peter Radlberger (p.radlberger@blackbox.at)).
Television IF amplifier and demodulator.
Supply voltage (pin 11)                         - 12V,
Video output voltage (peak-to-peak, pin 12)     - 2.7 V
AFC output voltage swing (peak-to-peak, pin 5)        - 10 V
Pin 1:  Balanced IF input
Pin 2:  IF amplifier decoupling
Pin 3:  Tuner AGC starting point adjustment
Pin 4:  Tuner AGC output
Pin 5:  AFC output
Pin 6:  AFC on/off switch and sample-and-hold capacitor
Pin 7:  Reference carrier pi/2 rad.phase shift
Pin 8:  IF picture carrier passive regeneration
Pin 9:  IF picture carrier passive regeneration
Pin 10: Reference carrier pi/2 rad.phase shift
Pin 11: Positive supply (Vcc)
Pin 12: Video output
Pin 13: Gnd (Vee)
Pin 14: IF AGC capacitor and VCR switch
Pin 15: IF amplifier decoupling
Pin 16: Balanced IF input
104. TEA2037A - ECG1888
Horizontal/Vertical deflection output, Vcc = 14 V. 16 pin DIP.
Pin 1: Frame osc
Pin 2: Flyback generator
Pin 3: Frame flyback
Pin 4: Gnd
Pin 5: Gnd
Pin 6: INPUT Inverse
Pin 7: Frame power supply
Pin 8: Frame OUTPUT
Pin 9: Line Osc.
Pin: 10: Phase Detector
Pin: 11: Flyback
Pin: 12: Gnd
Pin: 13: Gnd
Pin: 14: Output Line
Pin: 15: Input Video
Pin: 16: +Vcc
105. TEA5500
Coded locking circuit for security systems.
(From: Paul Grohe (grohe@galaxy.nsc.com)).
Vs 7V max, Is 1.8-3.2 mA, 8 V zener across supply pins!!!
Pin 1: Gnd
Pin 2: Cosc         Ocsillator capacior to Vp ~1nF
Pin 3: S2        Output 2        Open collector, active low
Pin 4: S1        Output 1              "
Pin 5: E10
Pin 6: E9
Pin 7: E8
Pin 8: E7
Pin 9: E6
Pin 10: E5
Pin 11: E4
Pin 12: E3
Pin 13: E2
Pin 14: E1
Pin 15: DATA        Data input
Pin 16: Vp        Pos. supply
Encoder: Pin 15 to Vp, Output: tie pins 3&4 together, this is your
output, open collector. E1-E10 set code (connect to either Vp or gnd).
Key V+ to transmit.
Decoder, pin 15 to Vp, E1-E10 set code, pins 3&4 open collector outputs
active when code matches. Third unsucessfull try disables input! (three
strikes and your out!)
Illegal codes are E1-E10=High or E1-E9=High with E10=low.
106. TL494 - ECG1729
Pulse width modulator control circuit.  Vcc = 15 V typical.  16 pin DIP.
Pin 1: Non-inverted in
Pin 2: Inverted in
Pin 3: Feedback
Pin 4: Dead time control
Pin 5: CT
Pin 6: RT
Pin 7: Ground
Pin 8: Collector 1
Pin 9: Emitter 1
Pin 10: Emitter 2
Pin 11: Collector 2
Pin 12: Vcc
Pin 13: Output control
Pin 14: Vref
Pin 15: Inverted in
Pin 16: Non-inverted in
107. UA78GU(1C) - ECG953
Adjustable regulator, 5 to 30 V, 1 A.
               | O | <-Common (heatsink tab)
                1234
Pin 1: Common
Pin 2: Input
Pin 3: Output
Pin 4: Control
UA2240CN - ECG893 - SK7712:
Programmable Timer/Counter.  Vcc = 5 V typ.
Pin 1:  Fo (out)
Pin 2:  Fo/2 (out)
Pin 3:  Fo/4 (out)
Pin 4:  Fo/8 (out)
Pin 5:  Fo/16 (out)
Pin 6:  Fo/32 (out)
Pin 7:  Fo/64 (out)
Pin 8:  Fo/128 (out)
Pin 9:  Ground
Pin 10: Reset
Pin 11: Trigger
Pin 12: Mod/sync
Pin 13: Timing/rc network
Pin 14: Time-base (out)
Pin 15: Regulator (out)
Pin 16: Vcc
108. UC3842AN
Switchmode power supply controller.  8 pin DIP.
Pin 1: Comp
Pin 2: Vfb
Pin 3: Isen
Pin 4: Rt/Ct
Pin 5: Gnd
Pin 6: Out
Pin 7: Vcc
Pin 8: Ref (+5)
109. ULN2003A - ECG2013
7 Input Darlington Driver 500mA
Pin 1: In 1
Pin 2: In 2
Pin 3: In 3
Pin 4: In 4
Pin 5: In 5
Pin 6: In 6
Pin 7: In 7
Pin 8: Gnd
Pin 9: Common connection point for the cathodes of the internal free
       wheeling diodes connected to each driver output.
Pin 10: Out 7
Pin 11: Out 6
Pin 12: Out 5
Pin 13: Out 4
Pin 14: Out 3
Pin 15: Out 2
Pin 16: Out 1
110. ULN3718M
Pin 1: Decoupling
Pin 2: Power Ground
Pin 3: Signal Ground
Pin 4: Output
Pin 5: Vcc
Pin 6: N/C
Pin 7: N/C
Pin 8: Input
111. ULN3751Z
Pin 1: Non-inverting input
Pin 2: Inverting input
Pin 3: Substrate/-Vs
Pin 4: Output
Pin 5: +Vs
112. uPA53C - ECG2084
5 Input Darlington Driver, 500mA.
Pin 1:  NC
Pin 2:  In 1
Pin 3:  In 2
Pin 4:  In 3
Pin 5:  In 4
Pin 6:  In 5
Pin 7:  Gnd
Pin 8:  NC
Pin 9:  Out 5
Pin 10: Out 4
Pin 11: Out 3
Pin 12: Out 2
Pin 13: Out 1
Pin 14: NC
113. uPC177C
Quad Comparator.
Pin 1:  Output 1
Pin 2:  Output 2
Pin 3:  Vcc
Pin 4:  Neg input 2
Pin 5:  + input 2
Pin 6:  - input 1
Pin 7:  + input 1
Pin 8:  - input 3
Pin 9:  + input 3
Pin 10: - input 4
Pin 11: + input 4
Pin 12: Gnd
Pin 14: Output 3
Pin 13: Output 4
114. X24C44
8 pin DIP.
Pin 1: Chip enable
Pin 2: Serial clock
Pin 3: Data input
Pin 4: Data output
Pin 5: Vcc
Pin 6: Store
Pin 7: Recall
Pin 8: Vss
