INDEX
V2.86 (05/25/1998)
- Table of Contents
- Chapter 1)  About the Author & Copyright
- Chapter 2)  Introduction
-   2.1)  Compact discs and the digital audio revolution
-   2.2)  Scope of this document
-   2.3)  Types of problems found in CD players
-   2.4)  Repair or replace?
- Chapter 3)  CD Digital Audio Technology
-   3.1)  General Introduction to CD Technology
-   3.2)  CD information storage and playback
-   3.3)  CD (disc) construction
-   3.4)  And you thought driving on a narrow winding country road was tough!
-   3.5)  CD optical pickup operating principles
-   3.6)  Optical pickup complexity
-   3.7)  For more information on CD technology
- Chapter 4)  CD Player Placement, Preventive Maintenance, and CD Care
-   4.1)  General CD player placement considerations
-   4.2)  Preventive maintenance
-   4.3)  CD lens cleaning discs
-   4.4)  CD protection and handling
-   4.5)  CD cleaning
-   4.6)  Should I really worry about cleaning my CDs?
-   4.7)  Can a dirty CD or dirty lens damage my player?
-   4.8)  Rental or library CD considerations
-   4.9)  Can a CD player damage CDs?
-   4.10)  Repairing a scratched CD
-   4.11)  Repairing top-side problems on CDs
- Chapter 5)  CD Player and CDROM Drive Troubleshooting
-   5.1)  SAFETY
-   5.2)  Troubleshooting tips
-   5.3)  Test equipment
-   5.4)  Test CDs
-   5.5)  Useful ways to mangle CDs
-   5.6)  Getting inside a CD player or CDROM drive
-   5.7)  CD enhancers
- Chapter 6)  CD Player and CDROM Drive Fundamentals
-   6.1)  Parts of a CD player or CDROM drive
-   6.2)  Power supply
-   6.3)  Electronics board
-   6.4)  The optical deck
-   6.5)  Typical optical decks
-   6.6)  Components of the optical pickup
-   6.7)  Classification of CD player problems
-   6.8)  Most common CD player problems
- Chapter 7)  Troubleshooting Guide
-   7.1)  Instant troubleshooting chart - most common problems and likely causes
-     7.1.1)  CD player is totally dead.
-     7.1.2)  CD player is operational but there is no display or partial display.
-     7.1.3)  CD player ignores you.
-     7.1.4)  Drawer does not open or close.
-     7.1.5)  Drawer operation is erratic.
-     7.1.6)  Drawer does not close (or open) completely.
-     7.1.7)  CD changer jams when selecting or ejecting CDs.
-     7.1.8)  Spindle table loose or sticks to clamper upon eject.
-     7.1.9)  Intermittent or erratic operation.
-     7.1.10)  CD player or CDROM drive overheats.
-     7.1.11)  Operation is poor or erratic when cold:
-     7.1.12)  Disc is not recognized displaying 'disc', 'error', etc.
-     7.1.13)  Disc spins in wrong direction or overspeeds and is never recognized.
-     7.1.14)  Pickup attempts to reset past inner track.
-     7.1.15)  Player won't let you go near it and/or use your favorite lamp.
-     7.1.16)  Seek operations take too long or fail to complete.
-     7.1.17)  Search, seek, or play starts correctly, then loses time or position.
-     7.1.18)  Short distance skipping.
-     7.1.19)  Playback gets stuck (rapid repeat).
-     7.1.20)  Occasional long distance skipping or repeating.
-     7.1.21)  Player gets stuck at approximately same time on multiple discs.
-     7.1.22)  Various tracking problems on portions of discs:
-     7.1.23)  Repetitive noise at disc rotation rate.
-     7.1.24)  Audio muting, noise, or distortion.
-   7.2)  General inspection, cleaning, and lubrication
-   7.3)  Lubrication of CD players
- Chapter 8)  General System Problems
-   8.1)  CD player is totally dead
-   8.2)  CD player is operational but there is no display or partial display
-   8.3)  CD player ignores you
-   8.4)  Drawer does not open or close
-   8.5)  Drawer operation is erratic
-   8.6)  Drawer does not close (or open) completely
-   8.7)  CD changer jams when selecting or ejecting CDs
-   8.8)  Spindle table loose or sticks to clamper upon eject
-   8.9)  Intermittent or erratic operation
-   8.10)  CD player or CDROM drive overheats
-   8.11)  Operation is poor or erratic when cold
- Chapter 9)  Startup Problems
-   9.1)  What is a startup problem?
-   9.2)  Startup sequence
-   9.3)  Procedure for validating the startup sequence
-   9.4)  Disc spins in wrong direction or overspeeds and is never recognized
-   9.5)  Pickup attempts to reset past inner track
-   9.6)  Player won't let you go near it and/or use your favorite lamp
- Chapter 10)  Tracking (Seek and Play) Problems
-   10.1)  Description of seek and play problems
-   10.2)  The seek process
-   10.3)  Diagnosis of erratic play
-   10.4)  Seek operations take too long or fail to complete
-   10.5)  Types of skipping problems
-   10.6)  Short distance skipping
-   10.7)  Playback gets stuck (rapid repeat)
-   10.8)  Occasional long distance skipping or repeating
-   10.9)  Player gets stuck at approximately same time on multiple discs
-   10.10)  Various tracking problems on portions of discs
-   10.11)  Repetitive noise at disc rotation rate
-   10.12)  Marginal play - internal controls are not marked
-   10.13)  Testing the sled for mechanical problems
- Chapter 11)  Miscellaneous Problems
-   11.1)  Audio problems - muting, noise, or distortion
-   11.2)  Problems with the digital circuitry
-   11.3)  Problems with the analog circuitry
-   11.4)  Voice (almost) missing from CD playback
-   11.5)  Problems with extended length discs
-   11.6)  Problems reading CD-Rs
-   11.7)  Problems recording CD-Rs
-   11.8)  Problems with anti-skip buffers
-   11.9)  Problems with CDROM drives
-   11.10)  Portable CD player/CDROM drive power considerations - batteries
-   11.11)  Portable CD player/CDROM drive power considerations - AC adapters
-   11.12)  Boomboxes and compact stereo systems
-   11.13)  CD player was dropped or got wet
-   11.14)  Repairing flexible printed cables
-   11.15)  CD player whine
-   11.16)  Objective lens popped out
-   11.17)  Testing the optical pickup
- Chapter 12)  Servo Systems and CD Player Adjustments
-   12.1)  Servo systems
-   12.2)  Play adjustments
-   12.3)  Adjustment procedure for noise or skipping
-   12.4)  Repetitive noise at disc rotation frequency
-   12.5)  Short distance skipping or sticking
-   12.6)  General servo adjustment procedure
-   12.7)  Tips for adjusting CDROM drives
-   12.8)  Low laser power
-   12.9)  Optical alignment
- Chapter 13)  Motors and Spindles
-   13.1)  Small motors in CD players
-   13.2)  Problems with small PM motors
-   13.3)  Testing of motors
-   13.4)  Reviving a partially shorted or erratic PM motor
-   13.5)  Replacement motors
-   13.6)  Motor bearing problems
-   13.7)  Spindle motor problems
-   13.8)  Spindle motor drive modification to minimize chances of future problems
-   13.9)  Spindle motor replacement
-   13.10)  Unknown spindle platter height when replacing spindle motor
-   13.11)  Spindle platform pulling
-   13.12)  Correcting spindle platform wobble
-   13.13)  Sled motor problems
-   13.14)  Sled motor drivers
- Chapter 14)  Notes on Specific Equipment
-   14.1)  Pioneer PD/M series players/changers do not recognize discs
-   14.2)  Pioneer PD/M series test mode
-   14.3)  Pioneer spindle motor voltage (operating normally)
-   14.4)  Pioneer spindle motor problems
-   14.5)  Pioneer PD/M series servo adjustment procedure
-   14.6)  Pioneer PD-7010 adjustment procedure (from Davidson)
-   14.7)  Yamaha CD3 adjustment procedure (from Davidson)
-   14.8)  Audio whine (not from speakers) and/or muddy sound with Sony CD players
-   14.9)  Notes on Sony CDU31/33A CDROM drives.
-   14.10)  Disassembling the Sony CDU31/33A CDROM drive
-   14.11)  Sony Playstation (and other game machine) problems
-   14.12)  Playstation appears dead
-   14.13)  PSX controller unreponssive
-   14.14)  General problems reading PSX discs
-   14.15)  Bouncing picture on some (Zenith) TVs
- Chapter 15)  Testing of Optical Pickup Assemblies
-   15.1)  Introduction
-   15.2)  When and why to test the pickup
-   15.3)  Required tools, documentation, and test equipment
-   15.4)  Precautions
-   15.5)  Basic description of optical pickup
-   15.6)  Identifying connections to the optical pickup
-   15.7)  Testing the laser diode while in the player
-   15.8)  Testing the laser diode with an external power supply
-   15.9)  Laser power adjustment
-   15.10)  Testing the focus and tracking actuators
-   15.11)  Testing the photodiode array
-   15.12)  Making the photodiode measurements
-   15.13)  Sony KSS series optical pickups
-   15.14)  Interchangeability of Sony KSS pickups
-   15.15)  Super simple optical pickups
- Chapter 16)  Items of Interest
-   16.1)  CD technology basic specifications
-   16.2)  Comparison of CD and DVD Specifications
-   16.3)  A down-to-earth comparison of digital and analog recording
-   16.4)  What is oversampling?
-   16.5)  What is an anti-aliasing filter
-   16.6)  How good are the digital filters in digital audio systems?
-   16.7)  Instant oversampling theory
-   16.8)  Is there a difference between CDs for 1X, 2X, or 25X CDROM drives?
-   16.9)  CDROM drive speed - where will it end?
-   16.10)  CDROM spins continuously even when not in use
-   16.11)  Golden ears and technohype
-   16.12)  That last little decimal point
-   16.13)  Totally worthless gadgets for CD enthusiasts
-   16.14)  More on CD enhancers - magic markers and anti-vibration disks
-   16.15)  Why is speaker cable like spaghetti?
-   16.16)  Can a CDROM disc damage a CD player?
-   16.17)  Performance testing of CD players
-   16.18)  Comments on test discs
-   16.19)  Custom test CDs using CD-Rs
-   16.20)  Controlling the pitch of a CD player
-   16.21)  Converting a CD player into a CDROM drive
-   16.22)  Using a CDROM drive as a stand-alone CD player
-   16.23)  SP/DIF digital audio interface
-   16.24)  Can I use the pickup from a CD player or CDROM drive for optical experiments?
-   16.25)  Taking a CD player overseas (or vice-versa)
-   16.26)  Sony portable service mode
-   16.27)  Portable CD player Q & A
-   16.28)  CD players in vehicles
-   16.29)  Who says CDROM drives are fragile?
-   16.30)  Most expensive replacement part of the century award
-   16.31)  Comments on Sony KSS pickup suspension problems
-   16.32)  Impress your friends with the power of your CD player
- Chapter 17)  Exploration and Tinkering
-   17.1)  Interesting CD player signals
-   17.2)  The CD player 'eye' pattern
-   17.3)  Focus and tracking drive or error signals
-   17.4)  Focus, tracking, and error correction performance
-   17.5)  IR detector circuit
-   17.6)  Laser diode fundamentals
-   17.7)  Laser diode life
-   17.8)  Use of a CD, CDROM, CD-R, or DVD disc as diffraction grating
- Chapter 18)  Service Information
-   18.1)  Advanced CD troubleshooting
-   18.2)  Web resources
-   18.3)  Suggested references
-   18.4)  Rubber belts in CD players
-   18.5)  Interchangeability of electronic and mechanical components
-   18.6)  Interchangeability of components in the optical pickup
-   18.7)  Aligning the lens assembly after replacement
-   18.8)  Recommended parts suppliers
